Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    Are you using the latest code?
    It's this one: https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-18#post-186795
    Give me some days, I need to update this thread...
  2. benmax
    1,552Coins
    Yes i use your latest code .
  3. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    You need to change these lines in the code:
    #define NUMBERACTUATORS 3
    for testing needs to be
    #define NUMBERACTUATORS 1
    If you are using just one actuator - this is contrary to the comment on this line
    Also check:
    #define UP HIGH // Define to set up direction as HIGH
    #define DOWN LOW // Define to set down direction as LOW
    You may need to reverse these.. Best of luck
  4. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    Also run these handy test programs to test the switches
  5. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    Thank's @robjos1 ,
    Forgot about the one actuator.
    Direction might be correct, if it moves in the direction of the minimum switch when starting
  6. benmax
    1,552Coins
    Thanks !
    Tested and i 've got the sequence calibration but as flypt described :
    I changed for one actuator and i changed the direction as you said define UP LOW and define DOWN HIGH
    Led blinks for 5 seconds before starting calibration
    - Actuator goes down looking for minimum
    - Actuator goes up looking for maximum
    - Actuator goes to the middle really fast (position zero) and waits for serial commands
    I haven't got the actuator which goes to the middle position . It still stays on the second switch and doens't go to the middle position .
    For the other program to test limit switch value did you use an esp32 because when compiling arduino software says that this program isn't for en esp32 .
  7. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    Wait, I'm inducing you in error.
    Sequence is (in new code):
    Go to max
    Got min
    Stop at min
    After the sequence, can you send positions to it and does it move?
  8. benmax
    1,552Coins
    Ok that means that the sequence is correct right ?
    ok i will test this after , could you point me a post where i can watch how to send positions pls ?
    Edit : but for exemple if i go out of the min position by rotating the motor shaft with my hand ( psu switched off / usb esp connected). and after i switch on the motor is looking for a position (i don't know which one ) at full speed and limit switch won't stop the motor (emergency stop ) . i don't know if i' m described what happened but i was surprised .
  9. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    I have this as well but it as soon as connected to Mover it all works fine. Try connecting to mover and it should re calibrate and move to the centre fine.
    Just to note the switch test code is simply to check the switches are working - which it appears they are otherwise the actuator would not reverse/stop on the switch so disregard this for now. The code may be for arduino but only requires a few minor syntax changes to compile on the ESP
  10. benmax
    1,552Coins
    Thanks ! will connect Mover to test !
  11. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    @benmax and @robjos1
    The ESP32 code, re calibrates the actuator each time you touch the limit switches.
    When you make the first calibration, the code knows where is zero and where is maximum in steps.
    Since we could loose some counts, the code tests the switches, and when they are pressed, it corrects the position.
    So if you press the maximum and the actuator is not at maximum, the code is going to think it was at maximum and since he want to go to zero, he moves fast to zero thinking it's correct.
    So, don't touch the switches!
    In the download of Mover, inside the examples folder you have some of my examples, you can open them and see the serial string and settings.
  12. benmax
    1,552Coins
    Thx for these great clarifications !!
    I’m a real beta tester ! I test all i can test lol ahah i know it’s not supposed to do such stupid things !
  13. benmax
    1,552Coins
    Just connected Mover but after the calibration setup , when the second limit switch was pushed the motor goes at the full speed but not in the middle position but he continues after the limit switch . it's like the stroke is outside the limit switch ...
    There is something also not good !
    I could also change the limit switch , invert physically their position !
  14. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi ,
    I would like to do some ajustements (P.I.D) on my Rig because some actuators oscillates again a little bit .
    With your code , I have only the option with P.I.D or I can change something elses like SMc3 ( Fpwm ,F p.i.d , PWM rev, Dead Zone ) .
    Thanks !
  15. benmax
    1,552Coins
    Hi ,
    I will test switch off the limit switch mini & maxi , because my setup is not correct according logical actuator movement !
    For my mounting i put the mini limit switch when the actuator is a his maximum stroke , so it’s not correct and it’s the reason why it doesn’t work.
    I will make a try and report here !
    Finally I just have to change the wiring lol i’m crazy !
  16. benmax
    1,552Coins
    So I changed my wiring to make it matching to the drawing !
    I had to change the define UP and DOWN and the new sequence is :
    - test the min
    - test the Max
    -stop at the Max after went a little bit out of the Max limit switch direction inside the stroke
    It’s where I am , tried to connect mover and it works but can’t move the actuator .Used as rig the actuator ( new feature) . Connection with board is ok ( esp 1 for 3 axis but only one existing Axis1a )
    any help or advice thx !
  17. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    Use this settings:
    Code:
    // Serial output configuration
    // Interface Type: Serial
    // ComPort: The one used by your ESP32
    // BitsPerSec: 921600 - If you want feedback on the serial monitor of the Arduino IDE, you have to change this to 500000 in the defines
    // Data Bits: 8
    // Parity: None
    // Stop Bits: 1
    // Bit Range: 15
    // Type: Binary
    // Interface string format: <255><255><Axis1a><Axis2a><Axis3a>
    /// Output Rate: Can be down to 1 ms
    In the string, send the 3 actuators, but since you have only one, send this: <255><255><Axis1a><Axis1a><Axis1a> or <255><255><Axis1a><0><0><0><0>
  18. benmax
    1,552Coins
    Tested both without succes .
    For the second string it's 4 <0><0><0><0> not only 3 <0><0><0> ?
    in the Mover 295 when you choose linear actuator from DOF I setup bit output 15 like your 6dof rig is it correct ?
    In this window linear actuator from dof there is no image and when you click on the arrow to view other image like in the 6 dof for the three images to watch dimensions , an error occurs '' unhandled exception blabla ''
    Edit : in fact the motor go forward and reverse continuously on the max limit switch and jerky ( not smooth )
  19. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,478Coins
    Yes, use 15 bits
    Yes, images are still missing... forgot to hide the buttons. Amateurish work. ;)
    The values are 15 bits, that requires two bytes, tha's why we send two zeros for each unused value.
    So the string should be:
    Mover allows you to use also this:
    <255><255><Axis1a><<0><<0>
    The two << means two bytes for the described number
    Is speed correct? Code should match what you have in the serial.
  20. benmax
    1,552Coins
    #define CALIBRATION_SPEED 50
    As i said the motor oscillate very slow and like step by step around the limit switch . a few step CW hits the limit switch , reverse CCW .
    Now playing with the rig with the slider (actuator test ) i can stop the oscillation , but the actuator doesn't go to the middle stroke .
    My actuator has 100 mm stroke could you send me how you will setup such an actuator .
