Folding 2DOF No Weld Build w/ Wheelchair Motors for VR Racing
Discussion in 'DIY Motion Simulator Projects' started by Stephen Berke, Dec 16, 2019.
  1. RacingMat
    21,082Coins
    I'd advice you to use springs and not gas spring: because often standard gas spring has a damping which slow down the speed. A speed reducing device would be bad for your motors which will heat (like driving while breaking...) ans reactivity would be compromised. ;)
    Springs will reduce the noise hopefully (by keeping the teeth in contact)
    but will not reduce the loss of reactivity and precision.
    that's a good idea to test springs: you'll make your own opinion! :thumbs
  2. RacingMat
    21,082Coins
    I should have mentionned "springs only on 1 side" :)
