value1
Forza Horizon 4 Plugin 2.0.0.0
Plugin for Forza Horizon 4
  1. Leandro Kemp
    Brasil
    - 10Coins
    Everything is working ok. Steam and
    Microsoft versions. Thank you.
  2. ivan jack
    ivan jack Member
    418Coins
    Can this plug-in work on FH5 too? I already have the game.
  3. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    could be possible, just make some changes on xml.
    ill try it at launch, 9 nov
  4. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    144Coins
    You already have it? How is it? Physics seem ok?
  5. ivan jack
    ivan jack Member
    418Coins
    It is better than 4 on that. the cars drive very good. On the horizon 4 I could barely finish a race. I played the rally story and had fun. The map is huge. Drifting is awesome, also better than before. I am hyped to try it in the motion sim when the plugin is ready.
  6. Keith
    Keith Active Member
    Electrician
    144Coins
    Sounds awesome. I usually only play VR games but I might have to give this a try. Thanks!
  7. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    How did you get it working with the Steam version? Did you use Loopback or something else?
  8. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    To get FH5 working with the Steam version, you need to set up port forwarding on your router.
    I have the Steam version and managed to get motion from it last night. If you plan to use the FH4 plugin until a proper FH5 plugin is created, it'll need to be a manual start version.
    Steps to get it running;
    1. Go to your router settings and navigate to port forwarding.
    2. Set up a port forwarding rule as the following; External ports = 4122, Internal ports = 4123. Click Save.
    3. Get your internet ip address and note it down.
    4. Launch FH5, go to settings, turn data out 'on', input your internet ip address in the ip address box, and lastly input 4122 in the port box.
    5. Press space bar to save the changes you made.
    FH5 will now work with motion and pretty much any other app you are using.
  9. EL mansouri
    EL mansouri New Member
    - 49Coins
    my how to access the router transmitter and change the internal and external port please
  10. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    You'll need to refer to your actual modem router manual as it will vary between brands / models. Search for "Port Forwarding".
  11. Sameer
    Sameer New Member
    7Coins
    Motion platform
    The platform is not detecting Fh4 , have tried adding in game HUD the IP address and port 4123 , but can't get it working. Can anyone help.
  12. FeifeiHooray
    FeifeiHooray New Member
    China
    50Coins
    Hi value1, thanks for your plugin. I met some problems with the data output from Horizon 4, please watch this video:
    I have turned on Data Output in Horizon 4, set IP 127.0.0.1 Port 4123, the data input in the Tuning center looks random and change rapidly, so the sim shake violently and almost threw me out.
    Could you please help me with that? Thanks!!!
  13. FeifeiHooray
    China
    50Coins
    Hahaha I changed Max/Min values but still do not work. Finally, I found the problem today because I type in Chinese and the computer default language coding is UTF-8, after changing it to Unicode, everything runs perfectly.
    Thanks for the plugin!
  14. paxton84
    paxton84 New Member Gold Contributor
    2Coins
    Need help! I Installed FH4 but the plugin want to start the game via steam. I have the Version from the Microsoft Store! Is there a way to change the installation path to get the plugin running with the game from the ms store? Thanks!
  15. paulopsx2
    brasil
    649Coins
    just use simtools v3, and plugin and other features its auto install.
