Forza Horizon 5
Discussion in 'SimTools Plugins' started by DTHCR, Nov 6, 2021.
  1. noorbeast
    154,735Coins
    +11,213 / 57 / -2
    In the Tuning Center the bigger the value the softer the motion, but over a greater range of axis movement, the smaller the value the more sharp (violent the motion, over a shorter axis movement range.
    Some of your values are really odd, such as heave and surge where the Max is very different from the Min value. It is not unusual to have small differences in Surge, to simulate gear changes, but not as much as yours: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
  2. FeifeiHooray
    FeifeiHooray New Member
    China
    50Coins
    Thanks for the reply, I changed Max/Min values but still do not work. Finally, I found the problem today because I type in Chinese and the computer default language is coding is UTF-8, after changing it to Unicode, everything runs perfectly.
    Thanks for the plugin!
  3. bill Robinson
    bill Robinson New Member
    15Coins
    hello everyone i am very new and I didn't know you could use a motion sim on xbox if its not to much to ask could someone explain how it works
    154,735Coins
    +11,213 / 57 / -2
  5. DawidMajewsi
    DawidMajewsi New Member
    - 227Coins
    Welcome everyone!
    What could be the problem? Movement in the game is not working in my Simulator.
    But when the game is loading, it moves from top to middle, and it stays that way.
    Any ideas?
