Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. trust928
    trust928 Member
    brazil
    435Coins
    Im using your firmware with ard.. but its freeking my computer how can i isolate it? Need Galvanic isolator? How can i implement theres some diagram for me to follow? My friend has the board etc.. and his computer runs normaly withougt isolation thats strange
  2. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    What is the problem exactly @trust928?
    What are the symptoms on your computer?
  3. trust928
    trust928 Member
    brazil
    435Coins
    Hey pipis20015
    Man im my setup is the ard+ small pcb to join the singal and the hbrigdes... when i move the slider in game engine, my screen flikers it keeps turning off and on when i tried to play a game when the simulator starts to move everything frozes... im sure its because of the commom ground, an friend has the same setup and board s but he doesnt had any problem i dont know why
  4. pipis2015
    Athens, GREECE
    10,248Coins
  5. trust928
    trust928 Member
    brazil
    435Coins
    Yeas they are isolated i have opened them and cuted the wire that goes to the case, so i think its not it and more sugestion?
  6. pipis2015
    Athens, GREECE
    10,248Coins
    Are the computer and the simulator power supply plugged in the same wall outlet?
    Try to use a different wall outlet for your computer and the simulator power supply.
  7. trust928
    trust928 Member
    brazil
    435Coins
    Yeas they are, whats going on with it in the same wall oulet?
    Anyway i fixed the issue by puting opto isolators..
    The firmware is very good..
    Just a bit jerk but i just need to config i think that the bits should tranfers more quick.. i feel a delay some times but maybe just configuration thanks to all
  8. RacingMat
    21,035Coins
    1/ can you tell us more on the isolators you're using?
    2/ good!
    3/ jerk: just check if it is a mechanical gap?
    delay: are you at arduino top speed in windows and Simtools? you can lower Tolerance parameter
  9. pipis2015
    Athens, GREECE
    10,248Coins
    Sometimes when the motors draw exesive amounts of current from the power supply ... I noticed some spikes on the voltage of the wall outlet (confirmed by my ups tripping on and off because it also detects the voltage difference).
  10. Johan Soegiharto
    Johan Soegiharto New Member
    Jakarta
    203Coins
    Hello, I would like to ask about the arduino code:
    #define RV 2 //beware it's depending on your hardware wiring
    #define FW 1 //beware it's depending on your hardware wiring
    What does it mean? Is it the connection between motor and the motorshield or is it something else?
    Thank you
  11. Pilgreem
    Pilgreem New Member
    327Coins
    Wow impressive, that awesome move.
    Good work, thanks for creating this DIY topic, that help me a lot.
  12. RacingMat
    21,035Coins
    yes, it is :)
  13. Johan Soegiharto
    Jakarta
    203Coins
    Hello RacingMat, I would like to ask about your arduino code. Did you use any PID Controller or other Controller in your code? Because I didn't find any controller that controls the feedback of the potentiometer. If there is, could you pointed out which part is it? Thanks in advance.
  14. RacingMat
    21,035Coins
    it's written in the code...
    Code:
        // PID : calculates speed according to distance
        pwm=195;
        if (gap>50)   pwm=215;
        if (gap>75)   pwm=235;
        if (gap>100)  pwm=255;
    there is only a P (Proportionnal) controller: the speed depends on the gap between real position and order.
  15. Johan Soegiharto
    Jakarta
    203Coins
    Okay, I get it now. So if I may know what kind of control system did you use? Is it linear control system or on and off control system or something else? Thanks...
  16. RacingMat
    21,035Coins
    It's not on/off as it's Proportionnal.
  17. EntonoX
    EntonoX Member
    Full Stack Developer
    The Netherlands
    121Coins
    Really nice build and a huge inspiration to my build 'to come' :) how are the motors holding up? fast enough to feel the fine details of movement?
  18. RacingMat
    21,035Coins
    yes Smolka are perfect to feel details! but they are no longer available...
    glad my tutorial is useful :)
  19. EntonoX
    EntonoX Member
    The Netherlands
    121Coins
    Thanks! Maybe i found a cheap replacement for the Smolka (NIDEC 404.458) motors. I have them in order right now and i expect them to arrive this week. Then off for a SIM build :D
  20. RacingMat
    21,035Coins
    Eager to see your project! :)
