Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. man05ru
    man05ru New Member
    53Coins
    2DOF, 6DOF
    Please explain two points: 1. What are potentiometers for? 2 how to put them correctly? referring to the engine. The potentiometer must first be set to 0 or what? the rest is still clear.
  2. RacingMat
    21,082Coins
    1/ potentiometers are here to get a feedback (where is the lever) to the arduino code
    2/ the best is to assemble them loosely with the motor. If wiring is not good, it won't break anything. You swap ground and 5V on the pot pins and next try is good.
  3. RacingMat
    21,082Coins
    Hi @yoren beyls !
    you could use Pololu - VNH2SP30 Motor Driver Carrier MD01B
    https://www.pololu.com/product/706
    or
    VNH5019 Motor Driver Carrier https://www.pololu.com/product/1451
    it's the same wiring than motomonster InA and InB for Direction and 1 pin for PWM
    yours
  4. PyroBlaze13
    PyroBlaze13 PyroBlaze131 VR Racer
    PC Repair
    Fortuna, California
    77Coins
    2DOF, 3DOF, DC motor, 4DOF, 6DOF
    love it! I am Wanting to Build a Motion Rig of my Own. this is Inspiring. Thank You
  5. CAI_77
    CAI_77 Member
    67Coins
    2DOF, DC motor, AC motor, Arduino, Motion platform
    hello, first I want to congratulate you for your excellent work, really a very good simulator, now I want to ask a question, do you have 24-volt motors and do you feed them with a 12-volt, 30-amp source? I am new and I built my simulator with 12 volt motors and my source is 12 volt and 30 amps
    153,884Coins
    +11,154 / 57 / -2
    The motors used in the original post were 12v: https://www.xsimulator.net/community/threads/from-atoz-2dof-arduino-wiper-playseat.4616/
    But 24v can be used with suitable drivers: https://www.xsimulator.net/community/faq/24v-motor-driver-where-to-buy.154/
    Genuine MotoMonster boards are no longer available, those available are clones and can be subject to faults: https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
    There are a range of possible control boards, depending on associated motor choice: https://www.xsimulator.net/community/faq/motor-drivers.11/category
    Building with 12V motors is common and there are many member project examples to follow. Choose appropriate control boards and hardware, along with a design suitable to the hardware chosen. SimCalc can help get your head around the tradeoffs in design Vs physics: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    The Design and many other sections of the FAQs are a great starting place: https://www.xsimulator.net/community/faq/
    Do plenty of research and where necessary ask questions on your own dedicated build thread, which you can start here: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  7. CAI_77
    CAI_77 Member
    67Coins
    thank you, thank you very much for your response, as I always say it is a pleasure to be part of this community
  8. RacingMat
    21,082Coins
    Glad you found valuable information!
    the motors were truck wiper motors, hence 24V
    When a 24V motor is powered up by a 12V PSU, its speed is half
    But torque should be the same provided the PSU can deliver enough current (A)
  9. CAI_77
    CAI_77 Member
    67Coins
    thanks for your answer, sorry for my query, I'm new to this world of simulators and my knowledge is very basic, I congratulate you on your simulator, it's great and it works very well, a hug friend.
  10. RacingMat
    21,082Coins
    utilise Google Traduction pour passer du français à l'anglais https://translate.google.fr/?hl=fr&sl=fr&tl=en&op=translate
    et vice-versa.
    you have some wires heating?! the diameter is too thin... what is the actual diameter?
    1 motor is smoking... Was it during stalling (blocage sous l'effort) or normal use?
    This would require some fan cooling but there is probably another problem behind this.
    please share several pictures (simple drag and drop in the text editor), it will help.
  11. Matthew Bangerter
    Matthew Bangerter Member Gold Contributor
    Mechanical Engineer
    Mesa, AZ
    72Coins
    @RacingMat
    First off want to say thank you as your original tutorial is what inspired me to build my rig something like 7 years ago and I have enjoyed it thoroughly! One issue I have always had is very jerky movement. For example if I go to output testing > axis testing and slide one of the motor axis very slowly back and forth, the response is not smooth, it is very jerky/stuttered. While this works ok for the quick motions in fast paced racing sims like gear shifts, there is alot of unwanted stutters. For flight sims with smooth motion it is unusable. My guess is that it has to do with PID tuning? Is it possible to do PID tuning with your original code to smooth it out? Or do I need to switch to SMC3 to do that?
    Is it possible that the problem is something besides PID tuning?
    Any help or insight would be amazing!
  12. RacingMat
    21,082Coins
    Glad you found inspiration!
    There could be many factors.
    First have you the latest version? In the first version there was a bug that jerked.
    Second maybe some play in the potentiometer linking?
    In the code, you can increase the Tol value to smooth.
    Third you could have a go with another firmware indeed.
    Yours
  13. Matthew Bangerter
    Mechanical Engineer
    Mesa, AZ
    72Coins
    Thanks for the quick response! I’ll have to go take a look at the code but I think I’m probably still using the same code from like 2016… so I can try the latest.
    So I just increase the "int Tol=20" value from the default of 20 to a higher number until it feels right? Do I need to edit the "brakingDistance=30" or the "gap>50" under the PID section as well?
    For the encoder link: I drilled a hole in center of the the gear hub on the wiper motor and then stuck the encoder shaft in the hole using hot glue so it possible there is a tiny bit of play though I think it is pretty tight.
    have you successfully used your wiper motor rig for smooth flight sims? Just trying to see if smooth slow motion is even possible with wipers.
  14. RacingMat
    21,082Coins
    yes just this parameter but I'm really surprised nobody felt the need to tweak that...
    What happen when you use the slider in Simtools output testing?
