Question Game Engine Crashes when launching Assetto Corsa
Discussion in 'SimTools DIY Version' started by Deaglex, Oct 28, 2017.
  1. noorbeast
    154,750Coins
    +11,195 / 57 / -2
    Did you have a look at .NET as @yobuddy suggested above?
  2. AussieStig
    AussieStig Member
    207Coins
    Paul, with the help of Yobuddy, I was able to solve my issue by deleting the AC plugin files in the local simtools folder. Re-install the plugin and re-patch the game. For security you might want to back up those files first. I cant remember the exact files, but simtools regenerates them once you restart the game engine. AC then sprang to life, hope this helps. Cheers AussieStig
  3. yobuddy
    51,704Coins
    I sent a PM on the matter also
  4. j0no5mith
    j0no5mith New Member
    214Coins
    Hi Guys, I am also having the same problem as above. Game engine crashed on launch of AC.
    This is a new W10 install. I used the same config from my old W7. All motion is working in Game Engine.
    I have removed / deleted the AC plugin and re-added via plugin updater so that everything goes green in Game manager (On / Patched / Connected).
    Soon as AC is launched, Game engine crashes.. :(
  5. j0no5mith
    214Coins
    Ignore the message above. It is now Fixed.
    I un-installed 2.25, deleted all config in appdata and installed 2.1 then manually re-added all the config / AC plugin. etc.
    Probably nothing to do with v2.25, and something with me copying my v2.1 config files...but it is now working :)
    Sim racing without motion is hard when you get a taste for it :)
  6. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    I have the same problem, but i don't know how to show you with txt or zip file.
    I deleted all Ac in my computer, all folders in my pc of asssetto corsa, in my programs, and in My documents. I re-installed the pluggin but nothing happens. When the assetto is starting, the game manager doesnt turns blue (game running), and the axis in game engine doesn't turn blue too, and the game engine finally crash.
    with 2 hours i have reinstalled all Ac jajajaj but i need a solution.
