Resolved Game Engine crashes
Discussion in 'SimTools DIY Version' started by Raredog, Feb 22, 2018.
  1. Raredog
    Raredog Active Member
    Denmark
    25Coins
    2DOF, JRK
    And obviously I have adjustet the feedback ;)
    154,657Coins
    +11,207 / 57 / -2
    Is everything properly grounded?
    And ca you please post pictures of all of your settings in the JRK utility and in SimTools.
  3. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Yes, but i haven't changed anything since simtools 2.0 was released, so it can't be in the settings I guess?
  4. yobuddy
    51,736Coins
  5. Raredog
    Denmark
    25Coins
    2DOF, JRK
    I tried disconnecting the pot meter from the axle and the motor responded fine, switched out the pot meter anyway. But when connected to the axle, feedback positions learned. It just violently drives to the mechanical stop! I don't get it? Why doesn't it do that when i manually turn the pot?
  6. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Okay, that was just me being dumb! The inverted feedback box was checked...
    But the problem still persists, new JRK, new motor and new pot meter...
  7. Raredog
    Denmark
    25Coins
    2DOF, JRK
    And now, out of the blue it works!!!(?)
    But the new JRK are running really hot, ~80c - that's about double the normal temperature?
    154,657Coins
    +11,207 / 57 / -2
    I mentioned it before but could there be a grounding issue? Double check all your wiring and connections.
  9. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Tried measuring the resistance to ground and it seems fine and is properly insulated.
  10. yobuddy
    51,736Coins
    What kind of motors are you running.
    It does sound like a grounding issue to me also.
    That seems pretty hot to me.
  11. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Ordinary 12v wiper motors...
    I can measure 11 Kohms resistance, that's about 10x of the left side, which is working flawlessly.
  12. yobuddy
    51,736Coins
  13. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Yeps :)
    But i have a feeling that the new(used) motor are old and worn, would that make the JRK work harder?
  14. yobuddy
    51,736Coins
    Maybe swap the motors and se if the problem follows the motor or the JRK.
  15. John Memeo
    John Memeo New Member Gold Contributor
    84Coins
    I'm not sure if I'm having a similar issue or something entirely different. I just updated to the newest version of SimTools, and when I open any game that was working with my setup, I receive one of your interfaces requires game engine to be restarted and no feedback or motion is given in any of the games.
  16. noorbeast
    154,657Coins
    +11,207 / 57 / -2
    Just checking that you changed your Interface Settings. The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
  17. John Memeo
    84Coins
    Thanks for the reply! I went from SimTools 2.1 to 2.2 - those settings appeared to be the same as before the upgrade however,
  18. noorbeast
    154,657Coins
    +11,207 / 57 / -2
    No Interface change needed then.
    Did you install directly over SimTools 2.1?
  19. John Memeo
    84Coins
    Yes I did.
  20. noorbeast
    154,657Coins
    +11,207 / 57 / -2
    What you could try is backing up your settings by zipping C:\Users\(Your User Folder)\AppData\Local\SimTools
    Then uninstall and reinstall SimTools 2.2
