Request (Feature) Game Plugin Requests
Discussion in 'SimTools Plugins' started by value1, Sep 21, 2014.
  1. Need for Speed series
    58 vote(s)
    21.2%
  2. GTA
    31 vote(s)
    11.4%
  3. Burnout Paradise
    17 vote(s)
    6.2%
  4. Grand Prix Legends
    20 vote(s)
    7.3%
  5. Nascar series
    11 vote(s)
    4.0%
  6. Battlefield series
    16 vote(s)
    5.9%
  7. D Series
    3 vote(s)
    1.1%
  8. F1 2014
    19 vote(s)
    7.0%
  9. The Crew
    15 vote(s)
    5.5%
  10. … (post your wish)
    155 vote(s)
    56.8%
Multiple votes are allowed.
  1. Blame73
    Blame73 Well-Known Member
    8,316Coins
    @SilentChill @Avenga76 What about the game, is it worth the €€ they ask for? Or is it just another Dirt game?
  2. SilentChill
    20,668Coins
    For such early access its pretty damn good judge for yourself :)
    Cant wait to see this develop.
    I like the handling I can feel the car so to speak and ermm yeah cant wait to get some decent cars bought. Quite a few issues with the rift at the moment but its still very playable.
    • Like Like x 7
  3. Blame73
    8,316Coins
    Thanks for the video, you got got a lot of shaking in your seat don't you? After one hour session on Dirt you gonna be quite tired.
    Traction loss on rally is a must have!
    Is the FOV adjustable? Seems like you're driving from the back seat.
  4. Imeleon
    Imeleon Member
    Construction Engineer
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Are you using simcommander 3 or 4. I tried with 4 using the dirt 2 profile both steam and none steam and couldn't get any motion going.
    Did you have to alter the hardware config file to something specific. As in the ip address of simcommander.
  5. SilentChill
    20,668Coins
    @Blame73 i am going to tone the roll down a bit it is a bit too much I have already done the pitch. Cant change the FOV yet and the view does seem way to big like assetto corsa did when they first released vr support. Hopefully will be a quick fix when they get round to it :)
  6. Imeleon
    Imeleon Member
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Someone Posted this on iracing forum. Not sure if this works for the rift as well.
    If anyone has a burning need to change the cockpit FOV (the in-game adjustments are pretty minimal) it's possible to do so...it's a bit of hassle but not too bad.
    You have to do it for each car individually, but once you've done it once you can whip through the whole batch pretty quickly...
    Here's the instructions in 13(!) easy steps [​IMG]
    1) You need the Ryder BXML Converter program - get it here:
    http://petar.outer-heaven.net/downloads/ccount/click.php?id=23
    Unzip that anywhere...
    2) Now navigate to Dirt Rally cars folder...
    for instance: X:\SteamLibrary\steamapps\common\DiRT Rally\cars\models
    In this folder are the individual car folders...they have 3 letter abbreviations, but it's pretty easy to figure out which is which...
    3) Say I want to edit the Lancia Fulvia's FOV...I would choose the 'ful' folder and locate the file 'cameras.xml'
    4) Copy the 'cameras.xml' file and paste it into the folder containing the Ryder BXML Converter.exe.
    5) Drag and drop 'cameras.xml' onto Ryder BXML Converter executable file - this will create a new file - an editable .xml called 'cameras.C.xml'
    7) Open 'cameras.C.xml' using wordpad.
    8 ) Find the line <View type="Head" ident="head-cam" reverseCamera="head-cam_reverse" and then a few lines below that you will see: ><Parameter name="fov" type="scalar" value="50.0000" />
    Change that value to your desired FOV.
    9) Now, one line below that you will see: <Parameter name="playerAdjustableFOV" type="bool" value="true" />
    You need to change 'true' to 'false.' The FOV change will not take effect if you do not change this too...
    10) Save this file with your changes.
    11) Now drag this newly revised 'cameras.C.xml' and drop it on the Ryder BXML Converter executable file. You will get a box asking you to "enter the converion type." Type '1' and hit enter. It should say 'success!' and will have created another .xml file called. 'cameras.C.C.xml.' This file is now properly fomated for the game.
    12) Now you just need to move this new file, 'cameras.C.C.xml', back to the respective car folder - in this case SteamLibrary\steamapps\common\DiRT Rally\cars\models\ful and them rename it 'cameras.xml'
    You probably want to back up the original file first rather than overwriting it...
    13) Launch the game and enjoy your new cockpit FOV.
    Don't be put off by these instructions...it really only takes about 1 minute or so start to finish once you gone through the process... [​IMG]
    I wouldn't know (since I'm only using a single screen) but if you're an eyefinity user, you can change the FOV universally by just opening and editing X:\SteamLibrary\steamapps\common\DiRT Rally\cars\generics\eyefinity_cameras_adjustments.xml
    • Useful Useful x 4
  7. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    For Triple screen users, set your FOV here:
    - Go to your <steam folder>\SteamApps\common\DiRT Rally\cars\generics\eyefinity_cameras_adjustments.xml and set the Fov angle as you wish.
    <CameraAdjustment class="Head">
    <Fov angle="85" />
    <Tilt percent="100" />
    <Position x="0.0" y="3.0" z="-40.0" />
    </CameraAdjustment>
    • Useful Useful x 4
  8. Blocos77
    Blocos77 New Member
    301Coins
    I'm waiting for Dirt rally plugin to !!!:)
  9. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,262Coins
    Sim Commander 4.
    Scroll down about half way through this guide and you will see how I got it going
    http://www.isrtv.com/forums/topic/17665-accuforce-and-non-supported-wheel-fix/
  10. Boomslangnz
    4,172Coins
    just curious, what is the better rally sim? Dirt Rally or Richard Burns Rally?
  11. Baptx
    Baptx Member
    Employé
    Haute-Savoie
    405Coins
    3DOF, SCN5, SCN6
    for the moment, the best sim rally is richard burns
  12. Wanegain
    Wanegain Active Member
    Bruxelles
    2,021Coins
  13. Imeleon
    Imeleon Member
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Thanks @Avenga76 . I tried that but still no joy. Would it be that the ip or port is a different number on my comp. any idea how to find this out.
  14. prodigy
    Croatia
    6,698Coins
    @Imeleon
    My setup is same as Avenga's and it's working fine with those ip adress and port..
  15. Imeleon
    Imeleon Member
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Damn it must be something else. Must be in sim com. I'll keep trying. Thanks anyway.
  16. zigzag49
    zigzag49 Active Member
    727Coins
    thanks the plugin
  17. michto35
    michto35 Member
    france
    92Coins
    thanks for the plugin:thumbs
  18. Wanegain
    Bruxelles
    2,021Coins
    Thank you for the plugin, You rock !!
  19. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Grand Prix Legends got my vote! The mother of all sims, and with the great active community and mods it is still a very nice sim to play!
  20. value1
    14,306Coins
    @bob williams, @BlazinH
    When I google GPL I find hundres of mods (well, kinda ;))
    I'm too lazy or too busy to find the "right" or "recommended" one.
    Please give me a hint.
