Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. yobuddy
    51,759Coins
    Jet afterburners actually.
  2. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    Michigan USA
    252Coins
    3DOF, AC motor, SCN6
    Could someone please kindly explain how to get the edited sound effects to show up in the profile editor? I click save settings after setting RPM like the example but all my options are blanked out and still save GameVibe1 thru 9
  3. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Had the same problem with F1 22 a few days ago. When I changed the UDP signal from 2022 to 2018 the labels changed to "rpm" and so on. So i guess it shows "GameVibe1" when it dont recieve the correct signals or signals at all.
  4. lVlemphiz
    Automotive Engineer
    Michigan USA
    252Coins
    So I was trying to get it to work with Forza Horizon 5. You're saying I have to be in the game transmitting a signal on the UDP for those options to show up or change?
  5. Blekkulf
    Molde
    342Coins
    When you have transmitted once I think you save high and low on the profile for that game, and then its "locked". Not sure, but I have all values and lables now when i select game profile without game running.
  6. Hermant Alexis
    Hermant Alexis Member
    238Coins
    Hi, does somebody know why I have sometimes uggly "beep" sounding like on an old gameboy console, when several bass frequency effects are triggered at the same time? I mean, is it a normal behavior that several bass frequency effects become a higher frequency wave?
    If somebody has already experienced that, thank you for help ;)
  7. sci666
    sci666 Active Member Gold Contributor
    1,210Coins
    ohey guys.... i have to try gamevibe because i want some vibrations in MFS2020 ... its kind of .... interesting ..but very laborious to configure it ... and also a bit restricted with the effects.
    dont get me wrong its fantastic what you guys have done with this software, but for racing games i prefer simhub, its so easy to configure and tweak the vibrations AND i have the full range of the sound card in my case i have 8 Channels (in a 7.1 sound card) - i use 7 of them at the moment . unfortunately simhub has only profiles for the racing games and not flight simulators :(
    is there a possibility to get a fully configured profile for games in gamevibe ? or do i have to do it by myself complete manually ?
  8. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    In this case, you have to config manually.
    If you want a great profile for MSFS or any flight game, buy SIMSHAKE. Its a great software with HIGH DETAIL configs for aviators!!
    https://simshaker.com/
  9. sci666
    1,210Coins
    Is it free? Mmhh Russian Software .... If not free I think i dont wanna Support any Russian Software house with my money These days....
  10. Arazok
    Arazok Member
    Computer scientist
    797Coins
    Guys, I would like to use GameVibe (again), installed it (v.2.0) but get a crash when I try to save the soundcard setup. The SlimDX.dll is not found.
    Where do I need to place it (in which folder) ?
    Currently it is in my GameVibe install folder: C:\Windows\Program Files\GameVibe
  11. Arazok
    Arazok Member
    Computer scientist
    797Coins
    Ok, it works now after putting SlimDX.dll to windows folder.
  12. Arazok
    Arazok Member
    Computer scientist
    797Coins
    Ok, here another q:
    I have only 2 buttkickers, one on the front, the other on the back of my rig (as left and right speaker of my amplifier)
    Is it possible to spread e.g. "collision" vibe to the front (left speaker) or to the right (right speaker) when I get damage/collision at the front or rear/back ?
  13. noorbeast
    154,747Coins
    +11,213 / 57 / -2
    Game Vibe and do front to back collision (surge).
    To quote the first post of this thread:
    Collision
    - can be run in 2D or in 3D when used with multiple transducers.
    When in 3D with a 4 transducers setup, each Collision effect jumps to the side it gets struck from.
    This creates a nice 3D effect when you collide with another object.
  14. Arazok
    Arazok Member
    Computer scientist
    797Coins
    Ok, thanks @noorbeast, but the setup of a soundcard in the first posts are really old. I have not seen any quadrophonic setup in Windows10. I am just using an inbuilt soundcard with my minipc, so 2D setup.
    Hence I just want to simulate front hit / back hit.
    Possible ?
  15. noorbeast
    154,747Coins
    +11,213 / 57 / -2
    So, can I please clarify what is the surround capabilities of your setup, it sounds like that maybe limited to 2d stereo?
    A cheap 5.1 USB sound card may open up possibilities in a cost effective way.
  16. Jimousse
    Jimousse New Member
    - 10Coins
    Hello.
    Why when I want to activate the Vibe output, I have the message that it is with a professional or entertainment licence ?
    Thanhs
  17. Jimousse
    Jimousse New Member
    - 10Coins
    I just realized that my license level does not allow the use of GameVibe and Game Dash.:(:(:(
  18. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    822Coins
    Hi, I just bought a vibe, but something is not working, I tried it with a 2.1 50x2 +100w bass amplifier, I put a subwoofer in (before buying a bass shaker)Testing the F1, you only feel an annoying vibration but nothing when you go over the edges of the track Maybe I'm wrong somewhere.I'm posting some pictures of the interface and settings.Please help me.
  19. FLORIN ROMANIA
    România
    822Coins
    Hello, I purchased vibe and set it up according to the examples, I attached an amplifier and a subwoofer (just for testing), but I can't get it to work properly, I'm also attaching screenshots, pls help,Where am I wrong?
  20. noorbeast
    154,747Coins
    +11,213 / 57 / -2
    Please post directly to the V3 Beta thread, so the @yobuddy is aware of your issue and can respond.
