vthinsel
Gran Turismo 7 - PS4/5 2022-12-03
Finally motion for GranTurismo on PlayStation !
  1. Fred Bear
    Fred Bear New Member
    Engineer
    148Coins
    Sorry to hear that your VR2 doesn't give the great image quality that is claimed and raved about online .
    Maybe worth a chat with Vthinsel..
    He said his PS5 / VR2 was giving great image quality on GT7.
    Maybe there are some settings to tweak?
  2. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    my psvr2 is totally fine, but the lack in detail in gt7 vr compared to non-vr is very obvious and breaks immersion - i guess that pc vr is way better, although i never played it, so far.
    but i love gt7 vr, it is the best i have ever played.
  3. Fred Bear
    Engineer
    148Coins
    Sorry I misunderstood...
    I did not realise the lack of detail aspect in VR.
    I have read some reviews, and they all say great image quality.
    I saw when I loaded GT7 yesterday, and did the initial setup, it gave me the option of higher frame rate, or better image detail
    I chose better image detail, as I'm only using an old 40 inch TV for PS and PC. 60 Hz max and 1080p. Plus the PSVR1.
    No immersion using the TV with my rig. Hence VR.
    I see on the forums and groups, a high spec PC and top end graphics give best results... It just needs a lot of money for the PC components.
    Thanks for the information.
    Appreciated.
    W
  4. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Hi guys,
    I just realized, that you use your rig with GT7 !!!! That`s great, and thanks to @vthinsel for the plugin !
    When installing the requirements, all dependencies are installed, but then I get an error when building.
    Building wheels for collected packages: salsa20
    Building wheel for salsa20 (pyproject.toml) ... error
    error: subprocess-exited-with-error
    × Building wheel for salsa20 (pyproject.toml) did not run successfully.
    │ exit code: 1
    ╰─> [7 lines of output]
    core_hsalsa20.c
    core_salsa20.c
    stream_salsa20.c
    stream_xsalsa20.c
    salsa20.c
    c:\users\dirk\appdata\local\programs\python\python311\include\pyconfig.h(59): fatal error C1083: Datei (Include) kann nicht ge”ffnet werden: "io.h": No such file or directory
    error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Community\\VC\\Tools\\MSVC\\14.16.27023\\bin\\HostX86\\x64\\cl.exe' failed with exit code 2
    [end of output]
    note: This error originates from a subprocess, and is likely not a problem with pip.
    ERROR: Failed building wheel for salsa20
    Failed to build salsa20
    ERROR: Could not build wheels for salsa20, which is required to install pyproject.toml-based projects
    I am using Python 3.11.9 and also installed the VS Buildtools for 2022 (but not sure if I installed the correct ones, there is a bunch of different buildtools. Should I use "Desktop development with C++" ?
    (6 GB necessary, uups !)
    Thanks for any hint.
    cheers,
    Arazok
  5. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Ah shit, just saw, that it points to "Microsoft Visual Studio 2017" path, which I have also installed on my PC.
    Mmh, what can I do, now ?
  6. Rico Mortis
    Rico Mortis New Member Gold Contributor
    84Coins
  7. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,058Coins
    Arduino, 4DOF
  8. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Yes, maybe, but I am a friend to build things by my own.
    I am not that familiar with pip and Windows.
    When doing the "pip install -r requierments.txt" I thought it just takes the source packages from the txt file and installs them.
    But what is doing the build, then ? (where the error comes, as it refers to the wrong MS VStudio)
    Someone know, how I adapt the path ? (so that MSVC22 is used and not MSVC17)
  9. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Ok, I managed to fix it. Installing the build tools for MSVC2017 solved the problem !
  10. Arazok
    Arazok Member
    Computer scientist
    791Coins
    When generating the exe, I get an error saying:
    Traceback (most recent call last):
    File "GT7Proxy.py", line 15, in <module>
    File "PyInstaller\loader\pyimod02_importers.py", line 419, in exec_module
    File "salsa20.py", line 18, in <module>
    File "imp.py", line 297, in find_module
    ImportError: No module named '_salsa20'
    [11336] Failed to execute script 'GT7Proxy' due to unhandled exception!
    I used
    pyinstaller GT7Proxy.spec
    as stated in the readme.
    Any idea ?
  11. vthinsel
    FRANCE
    6,058Coins
    Arduino, 4DOF
    No issue here, with python 3.10
    823 INFO: PyInstaller: 5.13.0
    824 INFO: Python: 3.10.7
    857 INFO: Platform: Windows-10-10.0.22621-SP0
    863 INFO: Extending PYTHONPATH with paths
    ['C:\\Users\\Vince\\OneDrive\\Loisirs\\SimRacing\\SimTools\\GT7\\GT7-XSim-Proxy']
    2004 INFO: checking Analysis
    2398 INFO: checking PYZ
    2635 INFO: checking PKG
    2847 INFO: Bootloader C:\Program Files\Python310\lib\site-packages\PyInstaller\bootloader\Windows-64bit-intel\run.exe
    2848 INFO: checking EXE
    2891 INFO: Rebuilding EXE-00.toc because GT7Proxy.exe missing
    2891 INFO: Building EXE from EXE-00.toc
    2892 INFO: Copying bootloader EXE to C:\Users\Vince\OneDrive\Loisirs\SimRacing\SimTools\GT7\GT7-XSim-Proxy\dist\GT7Proxy.exe.notanexecutable
    2978 INFO: Copying icon to EXE
    2987 INFO: Copying icons from ['C:\\Program Files\\Python310\\lib\\site-packages\\PyInstaller\\bootloader\\images\\icon-console.ico']
    3027 INFO: Writing RT_GROUP_ICON 0 resource with 104 bytes
    3027 INFO: Writing RT_ICON 1 resource with 3752 bytes
    3027 INFO: Writing RT_ICON 2 resource with 2216 bytes
    3027 INFO: Writing RT_ICON 3 resource with 1384 bytes
    3028 INFO: Writing RT_ICON 4 resource with 37019 bytes
    3028 INFO: Writing RT_ICON 5 resource with 9640 bytes
    3028 INFO: Writing RT_ICON 6 resource with 4264 bytes
    3028 INFO: Writing RT_ICON 7 resource with 1128 bytes
    3043 INFO: Copying 0 resources to EXE
    3043 INFO: Embedding manifest in EXE
    3045 INFO: Updating manifest in C:\Users\Vince\OneDrive\Loisirs\SimRacing\SimTools\GT7\GT7-XSim-Proxy\dist\GT7Proxy.exe.notanexecutable
    3091 INFO: Updating resource type 24 name 1 language 0
    3094 INFO: Appending PKG archive to EXE
    3261 INFO: Fixing EXE headers
    3821 INFO: Building EXE from EXE-00.toc completed successfully.
    Are you able to run the python script ?
  12. Arazok
    Arazok Member
    Computer scientist
    791Coins
    yes, the script runs great with "python GT7Proxy ..."
    Strange....
  13. Arazok
    Arazok Member
    Computer scientist
    791Coins
    BTW, using the "official" exe is also running great on my Desktop7Development PC. I see all the infos in the dosbox.
    But when i run it on my minipc (which I use for the rig), it runs, but I see a never ending scrolling text inside the dos box, no info. Need to catch it later or tomorrow, but it seems some encoding signs shown (escape sequence). Also strange.
    And I am not able to use the sway/surge, my movement on the axis is nearly zero, no matter what i configure.
    But I guess with your help I will get rid of the problems (as always) :)
  14. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Ah, the wrong/strange window output seems to be solved in message #12.
    So windows-curses is not part of the exe release 1.7.2 ?
  15. Arazok
    Arazok Member
    Computer scientist
    791Coins
    sorry, I was wrong in my message above. The error in message #169 is not occuring when generating the exe. This is sucessful.
    But the error is thrown when the generated .exe is started.
  16. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Guys, I drived now my first rounds with GT7 and my rig. Great feeling, I love it.
    But my Sway is somehow problematic. I only got values between +/- 0.3 in the TuningCenter and when checking with virtual axis turned on, the sway bar is very fast jumping from left to right. Any hints of what I can do ?
    Is this a setting problem or a known issue with GT7 plugin ?
  17. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Try a larger value in the TC, as that should give smoother motion over a greater range.
  18. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Ok, I will do.
    But it is exactly as in post #38, where the video shows the flickering/jumping of sway and surge.
    Should I provide a video or some debug logs ?
  19. Arazok
    Arazok Member
    Computer scientist
    791Coins
    Hi, I managed to get it working with GT Sport (and PSVR1). You need to adapt the port and the "crypto key".
    Here is an updated GT7.py script. You only need to use the command line '--gtsport True' in addition to play GTSport and get the telemetry out of it (or use the GT7 plugin).
  20. Arazok
    Arazok Member
    Computer scientist
    791Coins
