SilentChill
Grand Theft Auto 5 (Steam Version) Steam BuildID: 3531026
Sim Tools Game Plugin for GTA5
  1. fastrella
    fastrella New Member
    Argentina
    - 251Coins
    How to play the latest update of gta5 steam versión for use with oculus?
  2. fastrella
    Argentina
    - 251Coins
    Hello.
    How to play the latest update of gta5 steam version for use with oculus mod.
  3. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    @SilentChill , Now that the game has vr support, could you update the plugin for this version? If I do not update the game more so as not to lose movement, thanks in advance
  4. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    DC motor, Arduino, 4DOF
    Hi, I have a "standalone" version of GTA V, (not a Steam version), will this pluggin work on it ?
  5. J-1775
    J-1775 Aviator
    1,588Coins
    Do you say there is no GTA 5 version that supports BOTH VR and motion??
    I actually bought GTA 5 a few days ago ─ only because I've read about the VR addon (no VR, no buy). VR actually works quite fine, but I have no motion at all. It's patched, loaden, connected to my platform and "sending data" to the platform with 50Hz, but obviously it's empty data.
    I must add I find the wow64ext.dll in the Simtools folder, but not the GetBaseAddress64.dll. I've searched my whole system for it, but no result. The DLL certainly does not come with the latest plugin anymore.
    Does that mean, it is not necessary anymore? Or do I need to download an early version of the plugin?
    Thanks for any help and insights?
  6. polybasss
    Burgos Spain
    155Coins
    If you look back on this same thread you will see that the plugin stopped working a long time ago, before they released the vr patch, the main problem is that although they update the plugin for the current version of the game when the game is updated again the plugin will stop working
  7. J-1775
    J-1775 Aviator
    1,588Coins
    That's a real pity, but thanks anyway. When you say you'd be willing to not update the game again, you obviously have the standalone version, since I I wouldn't know how to exclude the Steam version from automatic updates?
  8. polybasss
    Burgos Spain
    155Coins
    Exactly, I have the non steam version, I suppose there is some way to make it not update
  9. fastrella
    Argentina
    - 251Coins
    For now I play with the joystick plugin, but it's not the same.
  10. J-1775
    J-1775 Aviator
    1,588Coins
    @SilentChill: At GitHub someone mentioned that SIMHUB supports GTA V, too: "You just have to select "DIRT 4" on SIMHUB>GAMES and that's it."
    I cannot confirm this, but might be worth a try. Maybe the load of adapting to every new GTA build could be delegated to Simhub? I personally wouldn't mind to have Simhub installed to "pre warm" the data. Even its premium version is only a few $...
  11. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    @SilentChill Hello friend, I have a problem with telemetry. The simtools turns blue when I open the game, but when I drive a car it does not detect any telemetry in the tuning center. Do I have to configure it before playing?
    I have seen on other occasions of games, that they put properties in steam and write (-telemetry) is necessary in gta v?
  12. J-1775
    J-1775 Aviator
    1,588Coins
    Hi renzorey18. The plugin doesn't work anymore with the latest GTA V builds. Head over to that thread and try the all new plugin (it's on github). Works fine for me, though it's still WiP. Good luck!
  13. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    Thanks buddy, it worked for me! It's just not quite right, because in the game when I'm in the car it simulates acceleration and g-forces when turning, but when I change from vehicle to helicopter there is a problem is that it turns everything the other way, for example when tilting the helicopter towards forward the simulator goes backwards so i think it should work out
    thanks for your help J-1775
  14. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    For now see my response here for a quick fix: https://www.xsimulator.net/communit...thookvdotnet3-plugin.14742/page-2#post-199109
