Hall effect potentiometer
Discussion in 'Electronic and hardware generally' started by AceOfSpies, Nov 27, 2013.
  1. noorbeast
    154,711Coins
    +11,210 / 57 / -2
    If you choose Hall sensors it is easy to direct drive/mount them, no gearing needed.
  2. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    So go with the 180degrees? Like this one?
    http://www.digikey.com/product-search/en?keywords=987-1392-ND
    Just to confirm, this work with Adruino and wiring is the same, except these important positive and negative need to be right?
    154,711Coins
    +11,210 / 57 / -2
    Yes those would be fine. It is a good idea to use a flexible coupling and those come in a variety of sizes to suit most mounting needs.
  4. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    I have never seen a hall sensor before... They have no friction right, meaning the shaft turn super easily unlike a wire wound pot? Does it have ball bearing to support the shaft?
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
  6. Nick Moxley
    17,057Coins
    The Bitech/TT pots have a bushing not a bearing unfortunately, but that bushing is pretty dang tough i might add.
  7. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
  8. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Well... I ordered 2x 6127 from mouser...
    But I found a few of these from some old project... the specs say they are Potentiometer, but man, they absolutely have no friction whatsoever and spin ultra smooth... wonder if I can use it.
    http://www.vishay.com/docs/57042/157.pdf
  9. lcturkey
    lcturkey Member
    163Coins
    did you buy the hall effect pots ? Do you need to change setup values in Arduino codes ? Do you know it ? I made a diy hall effect pot. it can control the motor but cant control the angle of the rots. Motors continue to turn doesnt stop at the position.
  10. lcturkey
    lcturkey Member
    163Coins
  11. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Just got them in yesterday, have not try it yet... I haven't read up on it. But did you make sure the + and ground is correct? I think this is important.
  12. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,136Coins
    2DOF, JRK
    I have the 180 Hall effects, but should have got 360's i think.
  13. noorbeast
    154,711Coins
    +11,210 / 57 / -2
  14. Slider
    Irrigation
    Brisbane
    1,136Coins
    2DOF, JRK
    The effective range seems to be less than 180 even if they are, Im worried if a motor runs over one side of the limit it will be outside all range and stop working. Just wouldn't have that issue with 360.
  15. noorbeast
    154,711Coins
    +11,210 / 57 / -2
    Most don't run anything like 90 degrees up and down on a motor, as the torque loss is really significant. Personally I use 40 degrees max up and down, so 80 degrees total. There is huge headroom left over.
  16. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,951Coins
  17. SilentChill
    20,660Coins
    • Funny Funny x 3
  18. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
  19. paulg100
    Bristol UK
    1,373Coins
    same resolution in a smaller range so more precision
    • Agree Agree x 3
  20. Nick Moxley
    17,057Coins
