help I do not know what to do Arduino + sabertooth
Discussion in 'DIY Motion Simulator Projects' started by dualclick76, Jul 12, 2015.
  1. dualclick76
    dualclick76 Active Member
    italia
    19Coins
    I ask you guys a question just to see if my Arduino works, the LED should light tx? or stay off? my I led tx rx off my LED lights
  2. BlazinH
    16,689Coins
    Your leds indicate correct operation. Rx only will light on your arduino when receiving data from simtools (which is tx the data). The arduino tx would only light when sending data back to simtools which you are not doing.
  3. dualclick76
    italia
    19Coins
    Why does not move nothing?
  4. BlazinH
    16,689Coins
    Can you get movement from your motors using Describe Software's live test feature as I already recommended?
  5. dualclick76
    italia
    19Coins
    ........ guys solved a problem now any another ...... I replaced Arduino now works with sim tools. for power supply use two dsp 600 hp placed in series after a few seconds of testing with the potentiometers go into protection. what power do you recommend? thanks to all for their commitment and support.
    PS. describe just do with the power it crashes.
  6. dualclick76
    italia
    19Coins
  7. dualclick76
    italia
    19Coins
    24v power supply which do you recommend?
    153,800Coins
    +11,150 / 57 / -2
  9. dualclick76
    italia
    19Coins
    guys i need more of your help. a strange thing happens. I completed all the connections do the test with simtools, ruotrando the pot right seems to work perfectly, just rotate it to the left the two power supplies in series dsp 600pb go protection, what can be wrong?
  10. dualclick76
    italia
    19Coins
    what is the pin 5 volt potentiometer?
  11. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    1 pin is for feedback and 2 others are for power supply: gnd and 5V, no matter which one.
    Just find the feedback pin.
  12. dualclick76
    italia
    19Coins
    5v pot1 together 5v pot2?
  13. dualclick76
    italia
    19Coins
    ground pot1 together ground pot2?
  14. Wanegain
    Bruxelles
    2,018Coins
    Yes you can like for gnd.
  15. dualclick76
    italia
    19Coins
    I do not know if I explained well
  16. Wanegain
    Bruxelles
    2,018Coins
    5V for pot1 and pot2 can be used on the same wire, like for gnd. By the way, all gnd from all cards must be connected !
  17. dualclick76
    italia
    19Coins
    I had some problems with simtools doing tests, I noticed that the engine heat up even if they do not move
  18. dualclick76
    italia
    19Coins
  19. Wanegain
    Bruxelles
    2,018Coins
    Can you please post pictures of your connections (and a drawing of what you connected) ?
  20. dualclick76
    italia
    19Coins
    As soon as possible I will thank you for your patience
