Help with FSX - No motion, tried all the options...
Discussion in 'Flight Simulator X' started by Archie, Apr 21, 2015.
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    P3D is great with the Rift, you have to back off the settings a bit but DCOC asynchronous mode does a great job even if the frame rates drop a bit. The only downside is the licensing restrictions, it does not affect recreational or commercial simulation but kills combat.
  2. boxsoft
    boxsoft New Member
    china
    212Coins
    pass by...
  3. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    @value1,
    Is a fix for the Steam version of FSX being worked on, or was there a workaround I haven't seen mentioned anywhere?
    Thanks in advance.
  4. value1
    14,237Coins
    The plugin also works with the steam version.
    You must run *all* simconnect.msi you find in the installation directory. This might be the issue.
  5. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    @value1 ,
    Thanks. Ran all 4 simconnect.msi I could find and that got me past the initial crashing, but now I have the EXACT same issues as @Archie had/has in his original post.
  6. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    @value1 & @Archie,
    It's definitely a problem with the Steam version only. I installed a copy of Flight Simulator X (Platinum Edition) and it had motion simulation right away. Does anyone have it working with the Steam version?
  7. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @Brett - Sorry man, I dropped FSX like a hot stone and went to P3D, never looked back. I removed FSX from my Steam Library. Even at the current $4.99 sale it's still $4.99 too much :)
  8. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Motion platform, 6DOF
    Hello I have FSX but I have not made the switch to P3D ,I heard that it does not go into 3d mode . I use 3dplay nvidea with the Benq 1070. FSX is perfect in 3d , Have you tried P3d in 3D?
  9. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Hope did you guys get the max Min values? I know on reaching games I just drove around, is it the same here?
    153,764Coins
    +11,149 / 57 / -2
  11. Asif Habib
    Asif Habib New Member
    Engineer
    Pakistan
    74Coins
    2DOF, 3DOF, Motion platform
    I am running FSX Steam Edition. The game patched successfully, already created the profile. Ran all .msi files but still unable to get the values on Tuning Center. The game is being detected by Game Manager & Engine.
    Can you buddies please get me out of this situation? Anybody please?
  12. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Does the SimTools Game Manager turn blue and say 'Connected'?
  13. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    I had the exact same problems as yourself and @Archie @Asif Habib . I use Prepar3D now, as it appears the Simtools plugin needs to be updated for the Steam version of FSX.
    Game Manager DOES turn blue and connect as far as I recall.
  14. Asif Habib
    Engineer
    Pakistan
    74Coins
    Yes it says "Connected" as well as the status changes to "Game Running" when I run the FSX
  15. Asif Habib
    Engineer
    Pakistan
    74Coins
    I am also trying FSX (No Steam Edition) but still unable to get any values on the tuning center
  16. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Run all the msi in all the folders under SDK in the fax folder
  17. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    There are at least four of them
  18. Asif Habib
    Engineer
    Pakistan
    74Coins
    I have run all the four of them already.. :(
  19. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Running one computer or two?
  20. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Do any other games work?
