Tutorial High Power Microsoft FFB2 Joystick
Discussion in 'DIY peripherals' started by T R Para, Feb 14, 2019.
  1. Soap
    Soap New Member
    47Coins
    Awesome, thanks so much for the answer. Should I also modify to board as described by the simprojects page previously linked? Or is just the MOSFETs and resistors required?
  2. Soap
    Soap New Member
    47Coins
    Oh and anything to watch out for when getting a power supply? I'm assuming any 24v/7A or similar DC brick should be fine?
  3. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    Just the chips and resistors. The other diodes were not needed. Yeah 24 volts is of course fine 7 amps should be enough.
    The weak link will be the motors.
  4. Soap
    Soap New Member
    47Coins
    Fantastic, thanks so much for getting back to me. If I put another pair of motors in should I wire them in series or parallel?
  5. T R Para
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    It would be parallel but I need to check if I am running 2 control boards or just one...
    I have not opened the box for years..
  6. Soap
    Soap New Member
    47Coins
    All good, no need to open it up to check haha. Thanks again for all your help
