Question How do i program and wire my arduino
Discussion in 'DIY Motion Simulator Projects' started by lyoso, May 16, 2026 at 14:28.
  1. lyoso
    lyoso New Member
    Today
    16Coins
    Hi!
    I am currently building my 2dof Simrig on arduino nano, with 300W motors, 400PPR coders type AB, BTS7060 drivers and a 24V 2x600W generators. I tired to hire chat gpt to help me in my code, but i'm still struggling. I don't really know if i wired my drivers to my arduino the right way, and i don't really know how to make it word with type AB coders too. My codes can currently recieve my coders info, but my right motor is spinning continiously when i send him a position request through arduino ide. I can't connect it to simTools too. Do you have any idee of how to do it?
    Here is my code:
    #define BRAKEVCC 0
    #define RV 2 //beware it's depending on your hardware wiring
    #define FW 1 //beware it's depending on your hardware wiring
    #define STOP 0
    #define BRAKEGND 3
    #define pwmMax 255 // or less, if you want to lower the maximum motor's speed
    // defining the range of potentiometer's rotation
    const int potMini=208;
    const int potMaxi=815;
    #define motLeft 0
    #define motRight 1
    #define potL A0
    #define potR A1
    // DECLARATIONS
    /* VNH2SP30 pin definitions*/
    int inApin[2] = {
    7, 4}; // INA: Clockwise input
    int inBpin[2] = {
    8, 9}; // INB: Counter-clockwise input
    int pwmpin[2] = {
    5, 6}; // PWM input
    int cspin[2] = {
    2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {
    0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13; //not explained by Sparkfun
    /* init position value*/
    int DataValueL=512; //middle position 0-1024
    int DataValueR=512; //middle position 0-1024
    // INITIALIZATION
    void setup()
    // serial initialization
    Serial.begin(115200);
    // initialization of Arduino's pins
    pinMode(statpin, OUTPUT); //not explained by Sparkfun
    digitalWrite(statpin, LOW);
    for (int i=0; i<2; i++)
    pinMode(inApin, OUTPUT);
    pinMode(inBpin, OUTPUT);
    pinMode(pwmpin, OUTPUT);
    // Initialize braked for motor
    digitalWrite(inApin, LOW);
    digitalWrite(inBpin, LOW);
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
    int sensorL,sensorR;
    readSerialData(); // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
    // the previous order will still be used by the PID regulation MotorMotion Function
    sensorR = analogRead(potR); // range 0-1024
    sensorL = analogRead(potL); // range 0-1024
    motorMotion(motRight,sensorR,DataValueR);
    motorMotion(motLeft,sensorL,DataValueL);
    // Procedure: wait for complete trame
    void readSerialData()
    byte Data[3]={
    '0','0','0' };
    // keep this function short, because the loop has to be short to keep the control over the motors
    if (Serial.available()>2){
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L'){
    Data[1]=Serial.read();
    Data[2]=Serial.read();
    // call the function that converts the hexa in decimal and that maps the range
    DataValueR=NormalizeData(Data);
    if (Data[0]=='R'){
    // call the function that converts the hexa in decimal and maps the range
    DataValueL=NormalizeData(Data);
    if (Serial.available()>16) Serial.flush();
    void motorMotion(int numMot,int actualPos,int targetPos)
    int Tol=20; // no order to move will be sent to the motor if the target is close to the actual position
    // this prevents short jittering moves
    //could be a parameter read from a pot on an analogic pin
    // the highest value, the calmest the simulator would be (less moves)
    int gap;
    int pwm;
    int brakingDistance=30;
    // security concern : targetPos has to be within the mechanically authorized range
    targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
    gap=abs(targetPos-actualPos);
    if (gap<= Tol) {
    motorOff(numMot); //too near to move
    else {
    // PID : calculates speed according to distance
    pwm=195;
    if (gap>50) pwm=215;
    if (gap>75) pwm=235;
    if (gap>100) pwm=255;
    pwm=map(pwm, 0, 255, 0, pwmMax); //adjust the value according to pwmMax for mechanical debugging purpose !
    // if motor is outside from the range, send motor back to the limit !
    // go forward (up)
    if ((actualPos<potMini) || (actualPos<targetPos)) motorGo(numMot, FW, pwm);
    // go reverse (down)
    if ((actualPos>potMaxi) || (actualPos>targetPos)) motorGo(numMot, RV, pwm);
    void motorOff(int motor){ //Brake Ground : free wheel actually
    digitalWrite(inApin[motor], LOW);
    digitalWrite(inBpin[motor], LOW);
    analogWrite(pwmpin[motor], 0);
    void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
    digitalWrite(inApin[motor], HIGH);
    digitalWrite(inBpin[motor], HIGH);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
    if (motor <= 1)
    if (direct <=4)
    // Set inA[motor]
    if (direct <=1)
    else
    // Set inB[motor]
    if ((direct==0)||(direct==2))
    else
    analogWrite(pwmpin[motor], pwm);
    void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
    // more readable function than Jim's (for educational purpose)
    // but 50 octets heavier -> unused
    if (motor <= 1 && direct <=4)
    switch (direct) {
    case 0: //electromagnetic brake : brake VCC
    break;
    case 3: //Brake Ground (free wheel)
    break;
    case 1: // forward : beware it's depending on your hardware wiring
    break;
    case 2: // Reverse : beware it's depending on your hardware wiring
    break;
    // testPot
    void testPot(){
    Serial.print(analogRead(potL));
    Serial.print(";");
    Serial.println(analogRead(potR));
    delay(250);
    void testpulse(){
    int pw=120;
    while (true){
    motorGo(motLeft, FW, pw);
    delay(250);
    motorOff(motLeft);
    delay(250);
    motorGo(motLeft, RV, pw);
    delay(250);
    motorOff(motLeft);
    delay(500);
    motorGo(motRight, FW, pw);
    delay(250);
    motorOff(motRight);
    delay(250);
    motorGo(motRight, RV, pw);
    delay(250);
    motorOff(motRight);
    Serial.println("testpulse pwm:80");
    delay(500);
    // Function: convert Hex to Dec
    int NormalizeData(byte x[3])
    int result;
    if ((x[2]==13) || (x[2]=='R') || (x[2]=='L')) //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
    x[2]=x[1]; //move MSB to LSB
    x[1]='0'; //clear MSB
    for (int i=1; i<3; i++)
    if (x>47 && x<58 ){//for x0 to x9
    x=x-48;
    if (x>64 && x<71 ){//for xA to xF
    x=(x-65)+10;
    // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
    result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
    return result;
