How to pick out the right valves?
Discussion in 'Pneumatic equipment - outdated' started by yobuddy, Mar 8, 2007.
  1. egoexpress
    Ah, wait!
    Arent the 1/4 the bigger ones?
    1/4 = 0,25
    1/8 = 0,125
    BTW: Do you want to build a RnR like design or a Platform? For RnRs and in the same size 1/8, like Illi uses them, should do the job.
    Perhaps for platforms the 1/4 ones should be better. I cant tell it to you for sure, because I never worked with air-valves.
  2. yobuddy
    51,221Coins
    Yes, 1/4 are bigger, same size as the air piston connections.
    I’m going to try to build a homemade R'n'R frame. No sense in re-inventing the wheel :wink:
    I would like to leave myself some room if I decided to add another two cylinders later, so I would have 2 for roll, and 2 for heave. If I decided it needs more strength and I have an adequate volume of air to run it.
    It would seem to me that going with 1/4 would make more sense since the air pistons are 1/4 connections also.
    I believe that both valves produce the same volume of air anyway, so it really does not matter I suppose.
    Thanks!
  3. yobuddy
    51,221Coins
    egoexpress, do you think i should go with 1/8 or 1/4?
    mabye you could ask illi for me
  4. egoexpress
    I think you should use the 1/8 ones with 1/8 air hoses and an 1/4--1/8 adapter at the cylinders side. Because it is tested and works.
    Buy the 1/8 ones. If you want to build a bigger sim some day, then you could sell them in ebay.
    But if you have doubts, ask illi by yourself
    regards
  5. yobuddy
    51,221Coins
    Sorry ego, I just thought you may post the question in German to illi, as I have come to realize babblefish is very limited in the translations. I believe that is why I miss a lot of info that may be ready available.
    Anyway, that’s a lot for all your help bro!
    I'll try posting the question in english.
  6. egoexpress
    Ok, Ok, I asked him.
    He mentioned that 1/8 is more than enough for RnR and even oversized for frex-like designs. But if you could get better sleep with the 1/4 ones, buy them. But use Connections for a 6mm air hose. You will have to use chokes anyway.
    The 1/8 have a airflow of 600L/min. How much airflow does your compressor provide?
    regards
  7. yobuddy
    51,221Coins
    Thanks allot ego, I do appreciate it!
    I'd say about 170L/min
    By my math at 222L/min the 2 cylinders (304.8 mm x 50.8 mm) (12 inch x 2 inch) would be able to extend and retract 180 times a Minute. Way more than is needed I believe.
    But since both the valves have the exact same flow data in the spec sheet, I’m wondering if it would make any difference anyway? The only difference in the valves is the connector.
    Thanks!
