Tutorial How to write a Game Plugin for SimTools 1.0 - API documentation
Discussion in 'SimTools Plugins' started by yobuddy, Aug 6, 2013.
  1. siemenson
    siemenson New Member
    Hangzhou Zhejiang China
    353Coins
    Good work, benifit a lot, Thank you.
  2. NelsonB
    NelsonB New Member
    software engineer
    Toulouse
    297Coins
    Thanks @yobuddy for the tutorial.
    I am starting an UDP plugin, and better at C++ coding than VB, but finding my way.
    One missing information in your tutorial is the specs for the LFS data you decypher in your code. I found them here (end of the file, search for OutSim). It helped me a lot to understand how you convert the game data into SimTools data.
    Nelson.
  3. yobuddy
    51,751Coins
    @Nelson,
    Unfortunately, LFS is one of the only games that actually breaks all this down for us.
    Some games it just a whole lot of trial and error.
    I would jump over to a 2.0 plugin as this info will be marked as outdated in a week or two.
  4. NelsonB
    NelsonB New Member
    software engineer
    Toulouse
    297Coins
    I would love to, but currently I only have SimTools 1.3.
    I had a look at your 2.0 tutorial, doesn't seem too different.
    By the way, if I can have access to SimTools 2.0, I 'll happily switch to it :)
    Nelson.
  5. xiejin
    xiejin New Member
    CHAINA
    94Coins
    This method supports FSX and P3D?
  6. KeithW
    KeithW New Member
    Oregon, United States
    69Coins
    I may have missed it in the thread, but after I have built a DLL, the Simtools Plugin Updater requires a zip file. Does it simply contain that one DLL?
  7. KeithW
    KeithW New Member
    69Coins
    I have been looking at the GTR2 source example in GTR2_V3_Source.zip . There is something I don't understand. The function
    Process_MemoryMap() allocates an array of 182 Byte's which is then copied to Struct_MMFSimBin. As best as I can tell the struct is only 181 bytes (45 Single * 4 bytes = 180 bytes, plus one Byte = 181 bytes). In other programming languages this would be copying off the end of the struct. Is my math correct? Does VB protect from this?
  8. value1
    14,297Coins
    The zip file shall contain the dll, the game banner (a jpg pic of 390×128 pixels) and the maxmin settings. However, the dll alone is good for a start.
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    ok. i read all posts here. but.. HOW can i CHANGE one plugin ready? example.. i need to change some info about NO LIMITS 2, or on JOYSTICK plugin... ( particulary, joystick plugin have inverted controls.. on right its a pitch roll, and left has a strange config... my joystick plugin have some files.. like a DLL, BANNER, and cfg. how to change values on it?
  10. SilentChill
    20,661Coins
    Version 1 is not supported anymore I suggest you upgrade to V2.1 ;)
  11. value1
    14,297Coins
    Hi @paulopsx2
    Essentially you cannot change the code of a plugin unless you compile the source code.
    However you can assign different axes to different output from the plugin or invert an axis in Game Engine and by that maybe overcome your issues as roughly described above. Check out the documentation of SimTools and the FAQ.
  12. paulopsx2
    brasil
    649Coins
    ?? About my question ? I m using 2.1
  13. yobuddy
    51,751Coins
    @paulopsx2,
    The answer to your question is in the post directly above your last. (value1 post)
    In short, there is no need to recompile the plugin to make changes, as all; the configuration is in SimTools itself.
    If the sim is moving backwards then you have you axis assignments setup incorrectly is all buddy.
    Please take a look at your axis assignments.
  14. paulopsx2
    brasil
    649Coins
    yeah... i follow this guide and all its work now rs thanks
  15. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    Bonjour
    Quel sont les fichiers et sous dossier qui doivent être présent dans le fichier zip pour pouvoir crée un plugin correct.
    Merci
    Hello
    What are the files and subfolders that must be present in the files zip in order to create a correct plugin.
    Thank you
  16. noorbeast
    154,723Coins
    +11,213 / 57 / -2
  17. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    Hello @yobuddy i'm right now very busy until thursday with exams and midterms, so i couldn't find what i was looking for in your instruction. Just ONE thing is all i need to know: i want to make a plugin for this game http://store.steampowered.com/app/556230/OffRoad_Paradise_Trial_4x4/
    the dev responds quickly on his emails usually. All i need to know is what should i tell him to provide for me? i know it's the telemetry output of the game, but is there a specific name for it that devs usually know..? what should i tell him to give me exactly..? i'll greatly appreciate a response from anyone who knows
  18. yobuddy
    51,751Coins
    Hi @Mpmo,
    First of all look here for a Game Plugin instructions.
    https://www.xsimulator.net/communit...ugin-for-simtools-2-0-api-documentation.9107/
    Version 1 is outdated and is not being supported anymore.
    Next, this link should give you a good idea of what you need buddy.
    https://www.xsimulator.net/communit...etry-output-into-a-game-simple-example.11080/
    And here is an example of a company getting simtools support.
    https://www.xsimulator.net/communit...plugin-for-furidashi-drift-cyber-sport.11772/
    I hope this helps buddy!
    Let me know how it goes,
  19. Arianus One
    Arianus One Tony Rom
    empleado
    Capilla del Monte,Cordoba, Argentina
    16Coins
    with what program do I open the plugin file? solution explorer?
    I need to modify a plugin
  20. yobuddy
    51,751Coins
