Tutorial How to write a Game Plugin for SimTools v3.0 - API documentation
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Apr 6, 2022.
  1. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    SCN6, Motion platform
    With help from copilot I managed build a plugin for the rc control app (MCRC) I am working on, the code for the plugin is a bit butchered as its my first attempt at a plugin.
    The plugin appears to work perfectly within the plugin tester environment, with the roll, pitch and yaw data streamed quickly and reliably however when I run the plugin within simtools3 I experience a few problems:
    The simulator is quite slow to respond to the data coming from the main app (that or the data is processed slowly) and the UDP data often drops, here is a log extract of the UDP data being dropped:
    Information - 26/11/2024 : Received data: -38.740000,-2.440000,-2.260000 Information - 26/11/2024 : Parsed Yaw: -39, Roll: -2, Pitch: -2 Critical - 26/11/2024 : Error converting data parts to Double: Thread was being aborted.
    This error results in the simulator getting caugh in a short cycle of motion outputs which go on until I close the MCRC app.
    Please let me know if I should have posted this message somewhere else in the forum, I keen to get this working so any feedback or help would be appreciated.
    Attached is the main code for the plugin.
    Thanks,
  2. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    I am looking for some help with updating a plugin to be able to pause and re-start ideally from a joystick button without having to pause the game or in my case underlying application.
    Is there a known method to activate / deactivate the motion output via an assigned controller input / command? A way to turn the output on / off (whilst in operation) via a button, ideally pausing the positon or sending the settings to a parked position but without stopping SimToolsv3 so that the user can jump back to activating the motion when wanted.
    Many thanks,
    David
  3. yobuddy
    51,589Coins
    I relise you plugins is a bit different than most, but most plugins itself themselves detect a state (like a paused state) and then set the var "_Status_Outputs._OutputActive = True or False" as needed. There is no remote profile api yet, but will be looked at in the future.
