hunijjang's 3DOF Motion Flight Simulator
Discussion in 'DIY Motion Simulator Projects' started by hunijjang, Apr 11, 2015.
  1. tailele
    tailele Member
    italy
    349Coins
    Could i ask to you where you buy the spring and the spring guide? thanks
  2. hunijjang
    hunijjang She is my wife :) Gold Contributor
    Operator
    Seoul, Korea
    1,164Coins
    Hello All.
    @tailele It is custom order production in korea. :D
    @noorbeast I have a big problems.
    because, worm gear motor is jitter when I lift on the upper plate for testing.
    like this I found it video.
    but if not lift on me of there then it is working well. :(
    could you will to the guess, what I need for this problem? thanks mate.
    154,750Coins
    +11,196 / 57 / -2
    Could you please post screenshots of each of the tabs in the JRK config program.
  4. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello. Thanks I will upload by tomorrow.
    as you known Motor : 12v 250W DC Motor + Worm Gear Head x 3(Motor Gear Ratios 60:1 and 50 RPM, Max 28A, Torque 28Nm)
    MEAN WELL Power Supply : 350W x 3(for 12v)
    the mean well psu is 0-29amp for operation.
    Hello @noorbeast :)
    That is working and not bad, I found problems about it, I am not sure 100% but maybe It is made low amp
    from the PSU.
    my PSU is have a - and + ADJ funtion(there can be turn with + driver but I did that - small size driver)
    so, I just adjustment them then working fit on me.
    but I disabled for the heavy by the last test time. :(
    I think these motor or PSU is not enough for 3DOF board on me. :oops:
    by the way, If I want to be making for high response it, What I needs to change for in the SimTools or Jrk 12v12
    Configuration Utility?
    Thanks mate.
    154,750Coins
    +11,196 / 57 / -2
    I am not totally sure what you mean.
    If by 'making for high response it' you mean how the motor is driven then that is in the JRK utility, with the PID controlling the behavior and the Motor tab the power and associated settings for the motor.
    The motors may spike over 40amps, so you need a good psu.
    How well does your spring compensate for the weight of the seat, peripherals and yourself?
  6. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
  7. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello All.
    I got just two 350w psu is fault when I tested in the psu shop. :( adj is not working and it just stay about 9v.
    by the way I bought two of 450 psu but today, one of psu is fault and not on on power so I will go to the shop for that check it 450 psu and also for will be 350w psu after service.
    I think overed for 1000w is something not working well with my home electric. :(
    because two fuse was down in the fuse box when I testing with all the of 1250w.
    I want be change to my platform design for compact and only 2dof for a seat and triple monitor.
    I some get an electrick shock. :(
    but that is ok by me. It is very dangerous lesson.
    154,750Coins
    +11,196 / 57 / -2
    It sounds like you need to get an electrician to check you home wiring. Unless you are playing around inside a PSU you should not be experiencing dangerous shocks.
