I would like to know about a motion sim, that can be built simply
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by marc79, Mar 15, 2016.
  1. rattler
    rattler
    Have you gone through the threads on DIY projects? Most of them work on balanced pivot point. So yes , back amd forth , left and right.
    Im guessing you have not spent much time digging around here.....
  2. marc79
    marc79 Member
    482Coins
    Caught me rattler but I did do some digging but it was overwhelming and didnt know one that supports Oculus, if someone can point me to the right direction.
  3. rattler
    rattler
    all motion is separate to VR. Its 2 different things.
    You can have one or the other or both
  4. rattler
    rattler
    Hahahaaa... they sounds about as bad as @bsft actuator sim .
    153,113Coins
    +11,117 / 56 / -2
    I consider VR needs fast accurate motion of 200+mm/sec. Otherwise you risk latency and that is the last thing you want in VR.
    Is the intent to use a pivot or rely on total lift. What is the all up load of the chair plus user(s)?
    See here for some recent discussion regarding loads and speed: http://www.xsimulator.net/community/threads/4-dof-simulator.8198/#post-101273
    Check out the FAQs for an extensive overview of most things related to building DIY motion simulators: http://www.xsimulator.net/community/faq/
  6. marc79
    marc79 Member
    482Coins
    I will need to handle at least 375 kg and one person
    153,113Coins
    +11,117 / 56 / -2
    Personally I would go with with spring assist for 375 kg, to keep costs down.
    I am guessing you have a particular chair picked out that significantly contributes to that weight? Just noting that unnecessary weight significantly contributes to the cost of moving it.
  8. marc79
    marc79 Member
    482Coins
    well I should say 300 KG I was kinda going overboard for heavier people
