value1
IL-2 Sturmovik: Battle of Stalingrad plugin 2.0.0.5
SimTools game plugin for IL -2 Sturmovik "Battle of Stalingrad"
  1. Historiker
    Michigan USA
    9,212Coins
  2. Jörg Ziegler
    Jörg Ziegler New Member Gold Contributor
    191Coins
    SCN5, SCN6, Motion platform, 4DOF
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,864Coins
    DC motor, 6DOF
    Hi @value1 ,
    The data transmission went without problems.
    I am using the angular velocities and linear accelerations.
    I am noticing something very strange. It looks like maybe the sway and surge are inverted.
    One question for the moment:
    Is there any math post treatment in the plugin or those are the raw accelerations and velocities?? I am not interested in the positions.
  4. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    working correctly for me, with the Steam version just bought, I need to adjust it but for the moment the movement is correct, I would like to feel the shots as with war thunder, I do not know if it will be possible ...
  5. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
    What platform is in use? Are you feeding it with surge and sway?
  6. Historiker
    Michigan USA
    9,212Coins
    The plugin seemed to be working well for me also, but I will try tonight to check on surge and sway. I am pretty sure they were working correctly as I do remember getting proper surge on takeoff and landing as well as a bit firing cannons.
  7. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
    Yes, fire the canon and modify the engine thrust 0 - 100 - 0 100 %. What is moving in this case, surge or sway?
  8. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
    Than, please take off and apply violently the rudder.
    Open “Tunning Center” and observe which values are moving.
    I see huge oscillations on the surge there while applying the rudder.
    Can you see it man?
  9. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Works perfectly for me as well, thanks!
  10. polybasss
    Burgos Spain
    155Coins
    2dof with pitch roll and surge
  11. Historiker
    Michigan USA
    9,212Coins
    Sorry, forgot to get down to the simpit the other night. Just finished a few flights in a LAGG and both sway and surge work fine. You can further test your setting by turning them all off and turning them back on one at a time while in game. To see if they effect your rig correctly. Works a treat.
    Except Yaw...that has never worked as I expect it to in any flight game. :(
  12. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
  13. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
  14. Historiker
    Michigan USA
    9,212Coins
    Thanks for the heads up, I will read through that thread when I get a chance.
  15. Historiker
    Michigan USA
    9,212Coins
    I tried your settings that you posted over there, and the newer plugin that @value1 posted there and I agree that it is better, for me it feels more fluid. I just need to figure out what setting does what. Right now my rig just undulates seemingly randomly (kidding). Yaw is not used at all (as a called force) and yet using extra 1-3 does give the exact right yaw feel. Roll and pitch are not used either but yet they are still there in output testing and in the motion itself. I need to figure out the combination that allows me to fix the direction of roll and pitch. Here is a copy of my axis settings, that I copied from your post over there.
  16. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
    To be clear, the settings on the photo are for 6dof platform only with use of kinematic plugin (heXpod or flypt).
    Those are related to the version of the plugin 2.0.0.5.
    If you updated the plugin to the 2.0.0.6 you have to swap the surge and sway.
    Sway (in the 2.0.0.6) is the lateral acceleration which can be mixed in DOF2 column with roll spin (extra2) in the DOF1 column
  17. Historiker
    Michigan USA
    9,212Coins
    I am using 6DoF for flight, my driving simpit is 3DoF. Until I get back from Europe anyway
  18. polybasss
    Burgos Spain
    155Coins
    I did not know that jet seat had support for this game, with what software do you get it?
  19. Piotr Janta
    Piotr Janta New Member
    Poland
    18Coins
    2DOF, SCN6
  20. polybasss
    Burgos Spain
    155Coins
