value1
IL-2 Sturmovik: Battle of Stalingrad plugin 2.0.0.5
SimTools game plugin for IL -2 Sturmovik "Battle of Stalingrad"
  1. noorbeast
    153,836Coins
    +11,151 / 57 / -2
    Please se my earlier post:
  2. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    @bob williams
    G'day Bob, The following works for me. I did not adjust any UPD ports, and just installed the IL-2 plugins as is, so these should be the default UDP's. Note addr1 for Simshaker and addr2 for Simtools. Any other sequence and they didn't work for me. You could remove the addr1 line if you don't have Simshaker. My rig is set up;
    SFX-100 > Simhub UDP=24321
    g-Seat > Simtools V3 UDP=4123
    Rumblers > Simshaker UDP=29373
    Add these if not present in the startup.cfg
    [KEY = motiondevice]
    addr = "127.0.0.1"
    addr2 = "127.0.0.1:4123"
    decimation = 1
    enable = true
    port = 24321
    [END]
    [KEY = telemetrydevice]
    addr = "127.0.0.1"
    addr1 = "127.0.0.1:29373"
    decimation = 1
    enable = true
    port = 24321
    [END]
    I have both Native and Steam versions of IL-2 installed. To run native, I start Simhub, select but not run the il-2 plugin, select the plugin profile and then enable motion. I start SimTools V3 and open the plugin settings but do not double click to start il-2. (Note, if I want to run the steam version then I would double click here in the plugin.)
    Once both softwares are up I open the IL-2 launcher dialog and start IL-2 from there. Both SimHub and Simtools will register that IL-2 has started.
    I hope this helps.
  3. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Thanks BrassEm! I was experimenting with motion in Simhub. My first impressions are very good. So for Il2 I can get all haptics and motion suited for my needs with only simhub and there is no need for UDP relay anymore.
    Thanks!
  4. Mikko Leino
    Mikko Leino New Member Gold Contributor
    Aircraft Maintenance Engineer
    Finland
    185Coins
    4DOF
    Thank you!
    I love the rate-of-rotation function. I always feel frustrated when I see a full 360-degree rig with a cockpit worth 50000$ spinning around, mimicing just the orientation of the aircraft.
    I find the rate function combined with AOA the most realistic combo. Pitch and roll function make sense only on ground.
    IRL if you fly level (1G) with high angle of attack, your seat is actually leaned back. I fly DCS with this setting and landing or high AOA manoeuvres feel amazing!
    I wish IL2 plugin would implement AOA also.
