Review INSECTA TECH Dragonfly CV1.C Build
Discussion in 'Commercial Simulators and Peripherie' started by Red_shift, Jan 18, 2019.
  1. Grizus
    Grizus Member Gold Contributor
    Warsaw PL
    349Coins
    I'm very curious :) I'm waiting impatiently;)
    this monitor is mounted only using the original Vesa mounting points ??
  2. Red_shift
    Red_shift Member Gold Contributor
    Charlotte
    361Coins
    Yes it is right now. Have had no issues to date, but then I have only had limited testing.
  3. Sam Dallas
    Sam Dallas New Member
    16Coins
    How is this coming ? Is it already up and running ?
  4. Red_shift
    Charlotte
    361Coins
    Right now I am in a hold mode. I have had some binding issues with the design so Jonathan has developed an new tube design that will eliminate this. I expect parts in another 2 weeks and once I get them retrofitted I should be all up and going.
  5. Thanos
    Electronics Engineer
    United States
    2,925Coins
    I hope your issues get resolved. Sounds like this was a rushed product...
    I hope you can get better motion at least than other DIY 6DOF platforms:
  6. Red_shift
    Charlotte
    361Coins
    Hi all, just a quick update that parts arrived today. It will take a couple of weeks for me to complete all of the work but now the process can start. :)
    • Like Like x 5
  7. Grizus
    Warsaw PL
    349Coins
    Hi :) any progress?
  8. Red_shift
    Charlotte
    361Coins
    Some, I have the new actuators but when I started retrofitting the first one we identified some differences in clearances between the old gearing housing and the new one. I was able to assemble and test the actuator with the new design and conform that it has resolved the binding issues but I was not able to completely tighten the gearbox housing as the clearance difference was causing binding on the gearing to its base plate. Jonathan is making me a new set of spacer rings that are a 1mm thicker that should solve this issue. These have now been completed and are on there way over. Once I get them I will finish the first actuator and do some testing, then complete retrofitting the rest.
    The good news is that the retrofit is relative easy and once I get going should not take more that about 2hrs per actuator. So getting closer. :)
    • Dislike Dislike x 1
  9. Red_shift
    Charlotte
    361Coins
    Hi all, I know it has been some time but I am making progress now. Have the new parts retrofitted to the problem actuators and all is working. I will post more soon but here is a small video. As you can see the sim take up most of my office. :D
  10. PetroVitallini
    PetroVitallini Member Gold Contributor
    Norway
    248Coins
    That's a sick looking sim! Looking forward to more videos.
  11. Erik Green
    Erik Green Member
    487Coins
    Do you have any pics that show the actuators extended?
  12. SeatTime
    Good to see it is all up and running :thumbs- have fun.
  13. Red_shift
    Charlotte
    361Coins
    No but if you look at the video there home position is a little over the midway of full extension. I would guess they have about 60 cm of displacement. Let's just say it's a lot! :)
  14. falkenfoxton97
    falkenfoxton97 New Member
    39Coins
    I just ordered a Dragonfly as well - shipping to the US! I did a lot of research before ordering and this seems to be the best out there (in the affordable range to an individual anyway).
  15. greatg67
    greatg67 Member Gold Contributor
    509Coins
    What are the footprint dimensions for this? Also, once the seat is mounted, what would be the required height for clearance? I would like to use such a system with VR?
  16. KNX873
    KNX873 New Member Gold Contributor
    296Coins
    SCN5
    Foot print is 7’X7’ but In a triangle it doesn’t have a square base. You would need 7’6” for head room from floor.
  17. greatg67
    509Coins
    Does the system come with game settings and presets? How simple is it to adjust customize the cockpit (i.e. attaching flight stick, throttle and pedals)? What is the max size of monitor that it can support?
    I'm very interested in this rig, but there does not appear to be any info on the web from users etc...just a bit gun shy at pulling the trigger!
  18. KNX873
    296Coins
    SCN5
    He has a support system for the Samsung 49” ultra wide monitor. Jonathan is really good to work with and will help you with presets and custom mounts if needed but has a good selection of mounts for flight stick thrust master throttle, rudder and wheel etc.
  19. GT3RS
    GT3RS New Member
    43Coins
    Any new updates on this? I’m thinking about getting a simulator to practice when I’m not at the track and looking for the most realistic one under$20k.
  20. Red_shift
    Charlotte
    361Coins
    My system is now up and running well. I will try to post an updated video this weekend.
