interface development
Discussion in 'SimTools compatible interfaces' started by symprojects, Sep 15, 2010.
  1. pointer4
    pointer4 Member
    Hungary
    276Coins
    I think i have a same problem.
    I have a second computer to handle the profiler, and X-sim hardware.
    But when is connect the SPI-D or RevBurner the cpu usage jump to 100 procent, and still there until reset. When i connect the hardware, and then start the Profiler, does the same.
    The GIMax working Fine. With the SimDash1.2 software the three hardware is working fine, from this computer.
    This is a clean XPsp3x86 install, with a 2.5+ Athlon CPU.
    Regards
    Poi
  2. symprojects
    symprojects New Member
    Hello.
    I am updating the Rev Burner and Spi-d plugins because I found I was doing something that stresses the CPU too much.
    I will post here when the updates are available, hopefully in a couple of days.
  3. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Thanks a alot!
  4. pointer4
    pointer4 Member
    Hungary
    276Coins
    I finished it now a two hours race, and the new SPI-D plugin working fine, and stable!!
    I hope its not a trouble, if I share it.
    • SPID.zip
      File size:
      115.8 KB
      501
  5. symprojects
    Thanks pointer4 for testing the new SPI-D plugin.
    I have updated the Rev Burner plugin as well.
    Hopefully the 100% CPU issue is now fixed.
    Download and instructions available here:
    http://www.symprojects.com/x-sim/
    Feedbacks very welcome.
    Cristiano
  6. pointer4
    pointer4 Member
    Hungary
    276Coins
    I tested it quickly in the morning, worked nicely.
    I found a mistake, that the rev profile file (xml), the import procedure not work.
    It loads, but the values didn't change.
    If I set the values manually, these remain.
    Regards
    Poi
  7. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Thanks so much! It works now! I just have problems with my cheap revmeter. The power supply that came with the revburner delivery delivers 13,8 Volt. But on the output for the revmeter at the revmeter delivers only 11,08V ... I have no idea why...
  8. pointer4
    pointer4 Member
    Hungary
    276Coins
    But it's working?
    Car devices work in wide voltage range. 9V to 14,8 V
  9. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Yes, it's working...
  10. symprojects
