value1
iRacing Plugin 2.0.3.2
SimTools game plugin for iRacing
  1. Globespy
    Globespy Member
    656Coins
    Yes, that's where it was by default.
    It could be something to do with Oculus or the way iRacing works with Oculus in VR?
    Either way, neither of these sliders help resolve the issue with the Pitch DOF.
    Thanks for trying to help.
  2. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Hi all
    I just started iRacing and i am hooked already ;-)
    I tried the pluggin and i get the .net error mentioned by some people here.
    I got some motion still ( so the pluggin is active) but motion is wrong. I use the same settings as with my other sims, so this .net error my provide wrong calculation
    Have you been able to solve this issue? how?
    thank you!
    154,849Coins
    +11,228 / 57 / -2
    @MrJack suggests the error is related to the start up order: https://www.xsimulator.net/community/threads/iracing-plugin.4774/page-15#post-193431
    Games do not always calculate forces in the same way. A motion profile should be dialed in for individual games, see the tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  4. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    thanks
    let me explain the problem . my servo has a range from -90 to 90 degrees
    on any sim , except iracing, when car is not moving, surge position= acceleration is null, servo position is= zero degree
    but on iracing, this static position is at servo = 45 degres
    so when accelerating full speed, i only access the range 45 to 90 degre instead of 0-90
    while the braking get -90 to 45.
    Do you have the same issue?
    is there a way to offset servo position to bring it back to zero degree when static?
    thank you
  5. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Problem solved!
    The heave is different on iracing. it is 'extra 2' instead. This is what was off setting my servos
    all good
    cheers
  6. VFX Pro
    VFX Pro Member
    Los Angeles
    472Coins
    Motion platform, 6DOF
    Can anyone explain what is the Heave-1 option and what does it do compare to normal heave? How does this input influences heave?
  7. Sebj
    Sebj Active Member
    Canada
    492Coins
    It's not used
  8. VFX Pro
    VFX Pro Member
    Los Angeles
    472Coins
    Thanks. Do you mean iRacing is not providing such value or you mean the plugin values could be set to 0 and it won't impact the motion?
  9. Sebj
    Sebj Active Member
    Canada
    492Coins
    Heave is only output on extra2
    You can set it to whatever, it won't be read
