iWrap - Multiple iRacing API Connections
Discussion in 'DIY peripherals' started by bvillersjr, Oct 19, 2010.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    I've heard from a few. All say they have turned it down some because it was a bit too agressive. Everyone seemed pleased to have an exact match of the on-screen motion with the simulator motion.
  2. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I currently use it and as Berney said, it allows for better synchronization of on screen motion with the motion coming from the platform. I had some crashing issues on startup and exit of iRacing while using the plugin so I will try the new version to see if that helps to correct it.
    I had to turn the effects way down to get the feel that I liked but I am very happy with it.
    Thank you.
    ....Mike
  3. knight0
    knight0 New Member
    I'm having trouble getting iWrap to work with X-Sim. I use the SimXperience Commander software and whenever I try to start iRacing, Force Sender crashes with the following error:
    X-Sim data collector has stopped working
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Force-Sender.exe
    Application Version: 2.0.0.0
    Application Timestamp: 4b82c86d
    Fault Module Name: iRacingPlugin.dll
    Fault Module Version: 1.0.0.9
    Fault Module Timestamp: 4ab42c5b
    Exception Code: c0000005
    Exception Offset: 00001c01
    OS Version: 6.0.6002.2.2.0.768.3
    Locale ID: 1033
    Additional Information 1: fd00
    Additional Information 2: ea6f5fe8924aaa756324d57f87834160
    Additional Information 3: fd00
    Additional Information 4: ea6f5fe8924aaa756324d57f87834160
    Read our privacy statement:
    http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
    I installed iWrap version 1.0.0.2 and the X-Sim plugin version 1.0 Alpha. Any help is greatly appreciated.
    Thanks!
  4. knight0
    knight0 New Member
    Figured it out. For some reason, the X-Sim plugin installer didn't replace the iRacingPlugin.dll file. Had to uninstall, delete the file, and reinstall. Now I have the file dated 10/15/10.
    Thumbs up to all those who contributed to this project!
  5. bvillersjr
    Ohio, USA
    438Coins
    Perhaps the sender was still open and the file was in use?
  6. knight0
    knight0 New Member
    Not sure, but that very well could've been the cause. Thanks, Berney.
  7. Papifix
    Papifix Member SimAxe Beta Tester
    im Ruhestand
    Friedberg
    562Coins
    What is the latest versions from EK`s SLIPro Manager and his iRPS hows work with iWrap ?
  8. vman
    vman New Member
    Could someone please email me the version of ek software for sli pro that works with ispeed.
    Thanks.
    Pm me for my email
  9. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    I am having difficulties trying to make this work ... Always getting ''Coudn't connect to iRacing Simulation'' error message when starting iWrap v1002.
    I want to use it to connect x-sim + motion cockpit view ...
    I have installed iWrap v1002 + iWrap x-sim plugin,
    I have downloaded motion cockpit view v1.5 and followed all the instructions...
    Could not even connect to iWrap ...
    Is there something else I need to install beside iWrap1002Setup.exe ?
    Thx!
    Bleco
  10. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Post from topic complete beginner, but it should be here:
    Here are the version numbers:
    - SLIProMgr_094d18c
    - iSpeed2.4.0.3
    - Force-sender 2.0 (X-Sim version 2.1.0.13)
    I also installed IWrap, however i don't use it, because if i remember correctly ISpeed has a IWrap proxy built in, but install it just in case.
    So this is the startup procedure:
    ISpeed->SLI-Pro manager->X-Sim force-sender->IRacing.
    @Bleco i think motion cockpit view also works in this config, just use ISpeed in combination with IRacing. Also install IWrap.
    Just to be sure here is the (X-Sim)Plugin i use:
    iRacingPlugin.rar
    Regards
  11. bleco
    Montréal, Canada
    258Coins
    Thx for the tip, it solved my connexion issue to proxy ;-)
    Everything seems to be set up but I still can't connect x-sim+Fanatec Thub+motion cockpit view even if iSpeed is connected to iRacing via iWrap... all 3 will work separately...
    Can we use 2.0.8.9b as well? or it as to be 2.1.0.13b ?
    Bleco
  12. splendiddd
    CCTV security
    Netherlands
    813Coins
    Its the same i think, i use the workshop edition :yes:
    I tested the motion cockpit view today, i works but you need to rename the IWrap_NPClient.dll to -> NPClient.dll ! (Just remove the IWrap word in the beginning of the file name.
    So, copy these files to your IRacing program dir from the GyroscopicTrackIRView dir:
    iWrapClient.dll
    Motion_Cockpit_View_Activator
    NPClient.dll (Formaly known as IWrap_NPClient.dll)
    Run the Motion_Cockpit_View_Activator as well as ISpeed,X-Sim and/or others.
    When you are in the car a beep sounds, telling you that the motion cockpit is active, you can disable it with CTRL+SHIFT.
    BTW: i have to test it more, but till now i don't like the add-on, maybe its because my screens are too big :lol:
    Regards,
    Rob
  13. bleco
    Montréal, Canada
    258Coins
    I have tried all day long to make this work together with no luck ...
    The only combinaison that is working is X-sim + iSpeed ... But I can't get them work with the cockpit view v1.5 and Fanatec THUD 0.4 ...
    I am able to run the cockpit view and Fanatec THUD separately ...
    This is what I have done for installation:
    Installed iWrap v1002.
    Installed iSpeed v2.4.0.3 and can connect to iWrap successfully.
    Installed iRacing Plugin For iWrap Setup v1.0.
    Installed cockpit view mod 1.5.
    I copied these files to C:\Program Files (x86)\iRacing :
    - iWrapClient.dll
    - iWrap_NPClient_CSP.dll (renamed to NPClient.dll
    Installed vcredist_x86.exe
    Double clic on Motion_Cockpit_View_Activator.exe and make sure the check mark is on.
    Fanatec THUD is v0.4
    I am not sure what to do next ... Is there an order to follow? I tried pretty much all options ... I also tried not to use the Fanatec THUD, no luck either
    Bleco
  14. bleco
    Montréal, Canada
    258Coins
    Ok finally,
    I can use iWrap to mix the motion cockpit view + x-sim + iSpeed ... another great addon to my sim!
    Issue was with iWrap ... don't know exactly what happened but problem was fixed after reinstallation ...
    Thx for this great tool!
    Bleco
  15. splendiddd
    CCTV security
    Netherlands
    813Coins
    Cool...what settings do you use for cockpit view?
    I think the default is a bit too much motion...
  16. bleco
    Montréal, Canada
    258Coins
