value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    Which settings are you looking for?
    Everyone's motion sim build is different, and so are the settings which work well.
    One piece of advice I can offer is that when using the joystick plugin with games "less is more" because if you crank it up things really start to feel fake and canned.
    Subtle movements are far more convincing.
  2. kevinmarz
    kevinmarz Member
    342Coins
    I have a Dof reality set up..I just need the setting to make the joystick to go front back and roll ,,,like do I use pitch first roll 2nd,can,t seem to get it..Thanks
  3. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Oh, OK understood.
    You'll need to have the Tuning Center open, and then move the joystick around, then make a note of which values correspond to which directional movement.
    Then enable and tweak those values in your axis assignments/movements.
    You can then disable ones which you won't need.
    Hope that helps.
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi
    Can this plugin be made to work with multi input devices?
    more of are now using seperate pedals etc ;)
    i know vjoy and gimx might be an option but those programs come with there own problems:(
    EDIT: Got pedals, wheel and shifter working with a Gimx Adapter off to test in game ;)
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    ps4?
  6. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    No, PC gimx works with pc as well
  7. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,978Coins
    Hey guys! In the absence of a Star Citizen plugin I'm looking at using this joystick plugin for flying in SC until they eventually (years off yet) expose telemetry. I did confirm with Chris Roberts personally that telemetry will get exposed when the game is finished as promised by a rather vaguely worded stretch goal.
    I just have one question, can you use a "button" input to change the response curve of other axes while held? I want this feature for "afterburner", which drastically increases acceleration in whatever direction you are applying thrust (may be surge, heave, sway or any combination of the three at any given point in time).
    So basically I just want the surge, sway, and heave cues to be increased by 50% to 100% when this one button is held. Can I do that?
    Thanks!
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    I’ve only had a limited play with this and I don’t think that’s possible all I could get out of a button press was a jolt which worked well as a fire button.:( Sozz
  9. Trip Rodriguez
    3,978Coins
    That's more or less what I expected, I wonder if this could be added?
  10. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    You ignore the DOF and just setup the directions base off movement ie if you press the gas pedal setup direction so your seat moves backwards, brake pedal moves forward etc
  11. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Once you get numbers in TC when moving wheel and press pedals you then need to take note of I will use Brake pedal as an example when you press the brake numbers will move in TC use that force ie roll to set direction in the axis assignments play with the direction buttons until you get the movement you want from the brake pedal.
  12. fra242
    fra242 New Member
    planes
    france
    86Coins
    hello
    it is possible to rec the values and after use the record with video ride recorder?
    for example : i Watch a video and i move the joystick in the same time, i record the telemetry of the joystick and i Apply this record in video ride recorder
    thank you
  13. value1
    14,305Coins
    "if you want to record the data – run SimTools_Joystick_Recorder.exe."
  14. fra242
    fra242 New Member
    planes
    france
    86Coins
    Hello, i saw in a post that probably the port to change or axis (b) to configure.
    I m not very sure but i think the guy have the same problem of you.
    Where i can find manual or tutorial for video ride recorder or video ride creator? Because you said to patch something and i dont see any information to install and how to use ( for a beginner) . I never use all this soft and i ll be happy to find a tutorial that explain step by step ;)
  15. fra242
    fra242 New Member
    planes
    france
    86Coins
    [QUOTE = "Sam Neall, post: 197911, membre: 33528"] Vous devez acheter SimTools professional pour que le lecteur de vidéo ride fonctionne avec votre simulateur. Vous pouvez utiliser l'enregistreur de trajet vidéo pour utiliser un joystick pour programmer vos films dans créateur de trajet vidéo. Assurez-vous simplement d'appuyer sur Enregistrer en bas pour écrire le code de mouvement. [/ QUOTE]
    Bonjour je vous remercie
    j'ai la licence pro de simtools.
    j'ai branché un joystick sur mon ordinateur, j'ai lancé l'enregistreur vidéo, j'ai lancé vrcinput, je déplace mon joystick mais je ne vois rien ...
    comment contrôler l'efficacité de votre joystick?
    EDIT: j ai réussis a utiliser video ride Creator, et d en sortir une video avec son fichier cfg de telemetrie. je l ai lue avec player video ride et les valeurs bougent donc ca marche.
    mais maintenant comment je peux utiliser ce que j ai fait pour faire bouger mon simulateur?
    Pour les jeux je mets le plugin dans plug in updater, puis je trouve le nom de mon jeux dans la liste deroulantye de simtools manager, je patch le jeu si besoin, et je lance simtools engine que je parametre ses axes puis je lance mon jeu et tout fonctionne mon simulateur bouge avec le jeu.
    Mais avec la video qu on vient de créer on fait comment?
    • Dislike Dislike x 1
  16. noorbeast
    154,819Coins
    +11,226 / 57 / -2
  17. fra242
    fra242 New Member
    planes
    france
    86Coins
    Im terribly sorry,
    I dont understand why, when i read its in french ( due to the translator i think ) and when i reply i put the translator to english but the reply its in french...
    I will verify more the next time, very sorry
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Whats the problem?
  19. fra242
    fra242 New Member
    planes
    france
    86Coins
    now i see values in tuning center :thumbs
    but i can changes values with the joystick in the video ride center...
    that is what i m doing to test if it work :
    1/i put the joystick exe in the seamtools folder
    2/i drag the zip file joysting plug in in the simtools updater plug in
    3/in the simtools manager i choice joystick in the menu
    4/ i patch and indicate the path c/programs x86/steam its ok
    5/ i launch jostyck .exe
    6/i launch tuning center
    now i see values of surge and sway that changes when i move my joystick
    i can say now it works
    But i dont know how use the joystick plug in to changes values in video ride Creator:
    1/ i launch video ride creator
    2/i load a video
    3/i launch simtools manager and i select joystick (the patch is done)
    4/i launch simtools engine and tuning center
    5/i launch joystick exe and i choice my joystick and i clic close
    6/i launch vrc input and i choice an effect (like surge)
    7/ i clic rec in video ride center
    8/i move the joystick but the first ball dont move, she move when i use the vrcinput cursor but not when i move the joystick...
    have you an idea ? i do a mistake?
  20. Camerus
    Camerus Sim builder
    California
    46Coins
    Motion platform, 4DOF
    Hi all,
    As anyone managed to make this plugin work with the Thrusmaster Joystick Hotas Warthog? I have other game controller on my PC including the Thrusmaster TWCS Throttle and rudder pedals. Both are working but I can't get the Hotas to work. Any idea or suggestion?
