Bug Just in time debugging and no connecting simtools engine to manager
Discussion in 'SimTools DIY Version' started by JDEWizard, Jul 15, 2023.
  1. Maëlig
    Maëlig New Member
    28Coins
    Hello, i have the same problem after downloading the EA WRC plugin on simtools. My version is simtools V2. I've watched a few videos about jit error but it didn't help. Any suggestions ?
  2. yobuddy
    51,652Coins
    Where did you get the EA WRC plugin buddy?
    As you can not use v3 plugins in SimTools v2, and as far as I know, there is no v2 EA WRC plugin available.
    Take care!
  3. Maëlig
    Maëlig New Member
    28Coins
    Firstly, thank you for your quick answer.
    I got it on the simtools website.
    You're right there is no V2 EA WRC, I downloaded a V3 version (I Saw it After).
    I have now the same error when i want to start the game engine or the game manager.
    Thanks for you answer.
  4. yobuddy
    51,652Coins
    You will need to delete the v3 plugin from your SimTools v2 plugin folder, as you can't use v3 plugins with v2 is all. So you will need to go to this path (%localappdata%\SimTools\GamePlugins) and delete the EA WRC plugin from the folder to get v2 working again.
    Take care!
  5. Maëlig
    Maëlig New Member
    28Coins
    Thank you so much, I was looking for the folder for like 30 minutes but it was only hidden... I finally found it and deleted it. It works now. Thank you again, take Care !!
