K8055 + Sabertooth + Wiper motors
Discussion in 'SimTools compatible interfaces' started by adbgg, Dec 19, 2010.
  1. Chris2
    Chris2 New Member
    Hi all,
    I have built my simulator recently with K8055 + Sabertooth + Wiper motors and adbgg made a presentation of it above.
    I made it in a couple of Weeks and after reading posts on forums => Many Thanks to all for the informations :thbup:
    @ egoexpress : do you really think my simulator is to slow, and are you sure it would improve it a lot by apllying load on shoulders ?
    Even after intesive use, my motors are cold, and they do not need to be cooled by fans.
    See this video showing complete view and tell me what you think about it please.
    Thank you very much, :cheers:
    http://www.youtube.com/watch?v=-glJOwCAhMg&feature=player_embedded
  2. bsft
    looks good, how do you like it?
  3. adbgg
    adbgg Member
    132Coins
    Hi all,
    A new french guy (Nexus_44) has just built his own prototype with K8055 + Sabertooth and wiper motors.
    Here is the link to the dailymotion video....
    http://www.dailymotion.com/video/xij0ju ... videogames
    Regards
    [img600px]http://www.dailymotion.com/thumbnail/160x120/video/xij0ju_essai-simulateur-dirt-2_videogames[/img600px]
  4. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    great job you guys :D
  5. guanfangfang
    guanfangfang New Member
    It is possible to connect Red+Green and use Brown for other motor connection, but I don't know what that does to these motors. You could try and tell us what happens.
  6. bsft
    Can you take a photo of what you are talking about please? And post it.
  7. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Im pretty sure he is talking about the high and low speed connections, and you only need to use the high speed connection. You dont want to go slow, there is no need to hook both.
  8. peruchito
    peruchito New Member
    Hola.Saludos.
    I have a velleman k8055 + a Sabertooth and I have a doubt.
    So that the exit of 5V of sabertooth is not connected to the velleman, entrances A1, A2 and GND with potentiometers?
    This way we will not need a battery 5V for the entrances A1, A2 and GND of velleman it.
    Thanks.
  9. BartS
    BartS Member
    417Coins
    The sabertooth 5v works for my k8055 A1,A2 and GND pots however with no pots connected it is 5.1v and with both pots powered it goes down to 4.9v.
  10. stephane-d.61
    stephane-d.61 New Member
    341Coins
    For my system (K8055+Sabertooth+Wiper motors), inputs S1, S2 and 0V are connected respectively to the outputs A1, A2 and GND of the K8055. 5V input is not used. I measured between the output GND/A1 or GND/A2, there was not quite a voltage of 5V
    I connected a supply of 14.5 V to pots B+/B- on the Sabertooth to offset the loss of input voltage.
    So, I get 11V to power the wiper motors.
    you can see my post on my forum that talks about this problem here : http://vos-playseat-stephaned61.xooit.f ... ce.htm#p90 (Sorry it's in French)
  11. peruchito
    Bravo. Very good.Estephane.!
    I am new and I have some problems.
    The system of the relay to deactivate the motors in case of continuous operation is very good idea.
    But as you drive a O1 exit in the Velleman with software xsim?
    I have visited your page but it does not explain it, or I have not seen it.
    Thank you.
  12. stephane-d.61
    341Coins
    In [Output setup]: left click on [Add new sequence block].
    Then left click on the line just created to select it.
    Click on [Add new output]. A window opens. In the dropdown menu, select the digital input on the K8055 which activates your relay. (for me, it's [K8055d Nr.0 Digital Output 01]).
    Below, click on [ON(1)] and [Accept selection].
    Do this for [sequence to move in positive direction] and [sequence to move in negative direction] in the [slow speed] and [fast speed], for each axis (motor left and motor right)
  13. peruchito
    OK.thanks!
    You have some configuration or to profiler yours x-sim?
    So far I do not defend much.
    Sorry by the annoyances.
    Thanks.
  14. stephane-d.61
    341Coins
    Each motion simulator is different and my setup does probably not work for yours. You need to do your own setting.
  15. peruchito
    Hello.
    already that each adjustment is personal for each assembly, but my assembly uses 2 wipers, one velleman K8055 and sabretooth like his.
    As I do not know very clearly the programming of x-sim to profiler, can you gibe me the profiler his like example.
    It could test to learn.
    Thanks and excuse the annoyances.
  16. frviana
    frviana New Member
    2Coins
    I am finishing building my simulator and my challenge now is understanding and building a game profile.
    Do you guys have a profile running with K8055 + Sabertooth for any game you could share?
    I've downloaded many others but they are either for SCN5 or they don't make any use of Reference Input on the output section.
    My simulator uses: K8055 + Sabertooth + Logitech G25
    Appreciate if someone could share a game profile using K8055 + Sabertooth.
    RFactor preferable but anything will give me some help.
  17. bsft
    Hello and welcome. What style of simulator do you have with wiper motors? Frex? Joyrider? Seat mover - simforce? I have some profiles for frex and joyrider, but would prefer to know what you have. I am running Pololu JRK's on mine , so the force profiles would be ok, you may need to fiddle with them further though.
    Thanks, David.
  18. frviana
    frviana New Member
    2Coins
    Thanks, I finally managed to get it working yesterday night. My simulator uses 2 wiper motors in the back and are attached to the back of the seat base.
    My main problem that I wasn't getting any further was that I had not installed the plug-in on rFactor therefore I wasn't getting any signal from the game and I thought it was my profile that had something wrong with it.
    I have a basic profile running now but now that the things is running I can learn how to improve the profile.
    Thank you
  19. bsft
    No worries, have fun fiddling with the profile! :cheers:
  20. frviana
    frviana New Member
    2Coins
    Have you guys figured out a good way to avoid the motor to keep spinning if the K8055 is not connected to the PC or the X-SIM is not on yet?
