KartKraft Plugin 1.0.0.1
SimTools game plugin for KartKraft
  1. noorbeast
    154,570Coins
    +11,190 / 57 / -2
    Unfortunately the plugin dev @Keir has not been around since September last year, so that is problematic.
  2. Gadget999
    12,331Coins
    no data in the tuning screen
    is it possible to get hold of the original plugin ?
    154,570Coins
    +11,190 / 57 / -2
  4. Gadget999
    12,331Coins
    Steam did an update today
    KartKraft now has motion
    Its awesome !!!
  5. fastvinnie
    fastvinnie New Member
    healthcare
    Amsterdam
    47Coins
    4DOF
    Yes it’s working, traction loss is a bitt jerky and strange in timing. And game vibe is not working.
  6. fastvinnie
    healthcare
    Amsterdam
    47Coins
    4DOF
    :) Seems it only works on a Saturday.. It stopped working again.. I’m puzzled about this..
    • Funny Funny x 2
  7. vin100lorant
    vin100lorant New Member Gold Contributor
    Professeur Electrotechnique
    Beynes
    191Coins
    Same thing....
    I have stop windows defender, unpatch and path the game.
    Nothing happens.
    An idea?
    Thanks:sos
    update :
    In fact, this work in local (127.0.0.1) but not with network between two pc...
  8. Gadget999
    12,331Coins
    there was a large update to KartKraft recently
  9. vin100lorant
    Beynes
    191Coins
    Hi, I'm coming back to you to find out if someone can help me.
    As i said in my previous post, I can get "game engine" and "game vibe" to work on the same pc as the "game manager".
    But as soon as I try to switch to my laptop (which works perfectly with asstto corsa, competizione, dirt rally 1 and 2, project cars), the 2 apps are connected, but the data (tuning center) remains at "zero".
    I tried to stop the 2 pc firewall, to open port 5000 in udp and tcp in "outpout" and in "input" ... but nothing.
    My two pc are connected by a switch, and each have their own fixed IP address.
    Does it come from the game (in the telemetry menu the IP cannot be modified ... 127.0.0.1) or from the plugin?
    Thanks for your help ... snif
  10. Demosux
    Demosux Love when my ass moving with pixel.
    Technicien audio-visuel
    Paris
    50Coins
    Hi there,
    Same to me. No data in tunning center.
    Hope an update soon of the plugin!
  11. Gadget999
    12,331Coins
    i tried it yesterday - it works
    do you have telemetry turned on ?
  12. Demosux
    Paris
    50Coins
    srsly? yes all it's done! I try again today, thx!
  13. Demosux
    Paris
    50Coins
    soooo, i have tryed again, and no, it won't. no data in tuning center. repatch, firewall and antivirus off, telemetry in game on. any suggestions?
  14. vin100lorant
    Beynes
    191Coins
    Yes Of course ! Remenber, it works on my local pc (manager + engine on my game pc, where there is kartkraft), so with the ip adress 127.0.0.1
    The IP adresse 127.0.0.1 is set by default in the game. But impossible mofify it. The Port number, yes we can ! I think if it 's possible to modify this ip, the problem will be solve (like in hardwareconfig file in dirt rally 1 and 2.0).
    What do you think about?
  15. Demosux
    Paris
    50Coins
    Ok, it's work now!!
    For reasons i don"t know the game were not patched by simtool.
    So, what i've done, it's a manual patch in game.ini
    if it can help >
    (appdata/local/project_k/save/config/windownoeditor/game.ini
    Open it with a wordpad prog then add this:
    [/Script/project_k.UDPManager]
    bConfigOverride=True
    OutputEndpoints="127.0.0.1:5000"
    OutputEndpoints="10.0.0.1:5001"
    bEnableOutputStandard=True
    Save, and it's all. The game send his data to tuning center.
    GL HF
  16. vin100lorant
    Beynes
    191Coins
    Your are amazing!!! It works!!!
    A big thanks!!! My son will be very happy tomorow!!
  17. Demosux
    Paris
    50Coins
    No problem :)
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  19. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi all so i just picked this game up its a blast for sure but im getting no motion, ive patched via simtools enabled UDP in game also tried this in the game.ini
    ive tried different ports and both simtools versions 2.3 and 2.4 but no joy
    simtools turns blue but no TC numbers, motion and vibe works on all other games without a problem any ideas?
    i also tried sim hub (without simtools runing ) and that wouldnt connect either.
    EDIT I got sim hub and simdash working with
    OutputEndpoints=127.0.0.1:4942 (simdash port)
    OutputEndpoints=127.0.0.1:4999 (sim hub port)
    but still no simtools ive tried
    OutputEndpoints=127.0.0.1:4123 and
    OutputEndpoints=127.0.0.1:5000 but still no joy
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    ok i found out that the port 5000 was being used by something else which is why some of you guys was maybe having it work some days and not others
    how i fixed it was open a cmd promt (run as admin)
    type netstat -ano | findstr :5000 for me this found
    UDP 0.0.0.0:5000 *:* 5664
    then type taskkill /PID 5664 /F
    SUCCESS: The process with PID 5664 has been terminated.
    you might have different PID number than me so change if needed
    i then just double checked it was closed by re entering netstat -ano | findstr :5000
    boom i got motion:cheers
