KartKraft Plugin 1.0.0.1
SimTools game plugin for KartKraft
  1. JohnCrichtonFR
    JohnCrichtonFR JohnCrichtonFR 5 DOF Gold Contributor
    Maintenance Technician
    22Coins
    4DOF, 6DOF
    You're welcome and happy new year ;-)
  2. stipecn
    stipecn New Member
    71Coins
    SCN5
    i have 3 coins.but i still cant download,i am a newcomer
    154,849Coins
    +11,228 / 57 / -2
  4. stipecn
    stipecn New Member
    71Coins
    SCN5
  5. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    302Coins
    Hi , no work for me anymore, tried unpatched and repatched. Big 10/2 update maybe?
  6. Magus
    Magus New Member
    87Coins
    I can't get this plugin to respond BUT I was wondering whether I need to run tuning for it to work.
    I am struggling the get the game to run in a smaller resolution/window (when playing in VR) so I can run the tuning app alongside it to see if it registering any inputs. I don't think it is.
    154,849Coins
    +11,228 / 57 / -2
    At a minimum you should have a base Axis Allocation and run capture Max/Min in the Tuning Center, for further tips see the FAQs here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  8. simracing34
    simracing34 New Member
    - 3Coins
    dear all,
    I have a problem with prosimu t1000 3M, traction loss does not work even with the last patch.
    Is there a trick to make it functional ?
    thanks
  9. Fabdenice
    Fabdenice New Member
    62Coins
    3DOF, Arduino
    hello, great I made the modification in the game.ini and it works perfectly now! thank you very much you are awesome
  10. Slashgnrs
    Slashgnrs New Member
    france
    211Coins
    SCN5, Arduino, 6DOF
    Modification of the game .ini works for my sim wind thx a lot. I hope it ll not give mess with the 6 dof on simcommander4 after that...
    • Old Old x 1
  11. Luca Sozza
    Luca Sozza New Member Gold Contributor
    - 338Coins
    Hi all, probably the game is been updated. The plugin stopped to work. Someone can checky it please? Thank you
  12. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Hopefully @yobuddy can check, when he has a spare moment.
  13. yobuddy
    51,779Coins
    Looks like the game now has a game.ini file that needs edited.
    Fabdenice instructions above appears to work.
    We will get it fixed up right after i get v3 to the alpha testers.
  14. Manes
    Manes Member
    179Coins
    ¡Hola! I can't move the sim with the Kartkraft and her plugin. I need open the 5000 Port? What IP for the Port?
  15. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Did you see these prior posts:
  16. Manes
    Manes Member
    179Coins
    Thanks Boss but I dont Found this file.... Where can o have It?
    (appdata / local / project_k / save / config / windownoeditor / game.ini
  17. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Game.ini can usually be located here:
    %localappdata%\project_k\Saved\Config\WindowsNoEditor\Game.ini
  18. nclabs
    196Coins
    Hi guys, I'm trying to make this game work but I had no luck. When I start the game the rig rise but I get no movement when I'm driving. Is there something else I need to know? Can you please screenshot me the settings page and your game.ini file? Thanks!
  19. nclabs
    196Coins
    I found the issue. It was Fanalab interfering somehow, when i close it the game works fine. Wtf
  20. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Could Fanalab have created a potential port conflict?
