KartKraft Plugin 1.0.0.1
SimTools game plugin for KartKraft
  1. nclabs
    196Coins
    Very possible
  2. TeckCam1982
    TeckCam1982 New Member
    - 27Coins
    have news of the plugin. i've a problem. no data in tuning
    154,576Coins
    +11,190 / 57 / -2
  4. TeckCam1982
    - 27Coins
    i try to use the last plugin, but not have any data in tuning window.
    game manager in pc gaming is patched and green flag, sim engine in another pc with correct connect.
    with any game have correct motion in my rig, but with KK not work.
    enable telemetry in 127.0.0.1:5000, no conflict port check with netstat.
    try to mod game.ini but i dont know the ip is 127.0.0.1 or the engine's IP
  5. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    Dartmouth, Nova Scotia, Canada
    818Coins
    I am experiencing the same problem, this plugin is no longer working for me. And I also check to make sure nothing was competing for it on port 5000 via the netstat command. The motors all engage when the game starts up, but then when I drive, they dont move at all.
  6. Nicki9knuckles
    Web Developer
    818Coins
    I tried uninstalling the plugin, using the plugin updater and the reapplying the plugin in the game manager but still no movment in game.
  7. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @TeckCam1982
    @Nicki9knuckles
    If you are trying to get this working on Simtools V3 then the only way I could get it to work was to unpatch it first from Simtools v2.5 hope this helps:thumbs
  8. Nicki9knuckles
    Web Developer
    818Coins
    @Daguru I gave your suggestion a try this morning and I still get nothing from simTools, and not values in the min and max settings during game play. Weird. I unpatched the game in both v3, and v2.5 then re patched it in v3 but not getting any aresponse from simtools
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  10. Nicki9knuckles
    Web Developer
    818Coins
    @Daguru I have it sorted out, you were right about the port. I had previously copied and pasted in "netstat -ano | findstr :5000 " but I must have put in a white space character and it came back with no resuts, but when I type it in manually I am seeing that Fanlab is using that port. So killing that I am able to get motion coming though. Thanks for the suggestion
  11. admarper
    admarper New Member
    73Coins
    Hello, has someone made the kartkraft run succesfully with simtools v3?
    The first problem is that I cannot patch the game when installing the plugin.
  12. noorbeast
    154,576Coins
    +11,190 / 57 / -2
    V3 plugins are available via the V3 interface, which is being added to all the time, v2 plugins are not compatible with v3.
  13. admarper
    admarper New Member
    73Coins
    Yes, I know, but I meant I have no acces to the screen where simtools ask you where is the folder of the game when you install the plugin for first time.
  14. Kaneda
    Kaneda New Member
    84Coins
    Same for me
    the window appears for a fraction of a second and disappears :/
  15. yobuddy
    51,679Coins
    The game required no patching at all, so it skips this page is all.
    For us the telemetry started working right away, do you have it working now?
