Level shift and amplifiy Pot signal
Discussion in 'Electronic and hardware generally' started by tombo, Nov 30, 2013.
  1. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    no problem for off topic this is only more input for me :)
    I have set pot min and max in my software but i thought of improove my sim a little bit.
    So i think i will let my sim like it is because i use wiper motors from junkyard and do some improovings when i find the right motors.
  2. BlazinH
    16,689Coins
    Thanks for that information on motor backlash @eaorobbie . But you have confused me with your statement of a 10ms analog read delay. I am new to arduino code but starting to pick up on it. My confusion comes from the statement in the arduino reference documents that says an analog read takes about 100 microseconds which equates to .1ms. Do you know of something I am unaware of or was this just a typo or math error? I'm not being critical but since I am learning I would like to know if I am missing something.
    http://arduino.cc/en/Reference/analogRead
    PS I also read that you can increase the rate by setting the ADC prescaler to as low as 16 which gives a read time of around 15 microseconds at the expense of a slight amount of accuracy.
  3. eaorobbie
    20,502Coins
    Opps me got the decimal place wrong, silly bugger I am will correct post thanks.
    But from my testing with Dashboards its still quite slow to use compared to whats on the market, its was really developed as a teaching tool, not a main stream Micro Controller that its proved its quite capable of, just a little restricted.
    Thanks for picking up my (yes ,calc) error.
  4. BlazinH
    16,689Coins
    Thanks @eaorobbie for un-confusing me on this. Unfortunately, the next confusion for me is just around the corner! :think
