looking for a short cut to ready built actuators!
Discussion in 'Commercial Simulators and Peripherie' started by Jerry Atrick, Jun 7, 2018.
  1. stargazer
    stargazer Active Member
    Electrical/Computer Engineer
    Boston,USA
    811Coins
    3DOF, Arduino, Motion platform, 4DOF
    thanks for the info guys. It looks like things from China may get a bit more expensive from now on. Lucky are those who already have their toys built before this week. If no one in the forum has tried this platform before then I think I will let it passes. I just don't want to be the first one to try something this complex and costly from China. If something goes wrong then I wouldn't know where to get support.
  2. Gadget999
    12,331Coins
    Use the alibab link above, pm me for the details of the salesperson
  3. Gadget999
    12,331Coins
  4. Bongo
    Bongo New Member
    Pensacola fl
    23Coins
    This is a quote I just received from China...the specs are pretty impressive if true. My main concern is still support after delivery.
    Quotation of Electric Cylinder
    Date : Oct 19, 2018
    Technical Specifications
    Rated Force: 0.52KN
    Max. Force: 1.4KN
    DGR, inline Cylinder
    parallel type, -Screw lead: 32mm
    round housing -Stoke: 500mm
    -Rated. Speed: 500mm/s
    -Max. Speed: 960mm/s
    SAMSR 86 Servo Motor motor with
    -Gear Ratio:1:1
    driver, DC75V
    -Precision: 0.02mm
    electric servo cylinder
    Lead Time 15 workdays
    Cylinder US$496.00
    6ea
    Servo Motor US$132.00
    6ea
    Total Amount US$3,768.00
    Protection IP54
    steel Material piston rod steel, non-corrosive
    Material screws Steel, Galvanized Material spindle nut steel
    Drive type ball screw Material cylinder barrel steel with paint coating
    Bearing: NSK
    Limit switch: 2 switches included, 3 wire PNP or NPN type,
    2m cable
    Services
    1. All products quoted above will be installed and strictly tested before delivery
    2. All products and accessories will be under one year warranty
    3. Lifetime maintenance service and remote technical advice
  5. Gadget999
    12,331Coins
    do you have photos of the actuators we can see ?
  6. Bongo
    Bongo New Member
    Pensacola fl
    23Coins
    Gadget999...This is what was attached to the quote...
  7. Gadget999
    12,331Coins
    They look pretty impressive
  8. Gadget999
    12,331Coins
    What do you think of this ?
  9. DotComRich
    DotComRich Member
    546Coins
    Has anyone gone ahead with these yet?
    What motion controller will work with them?
  10. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    Hi, sorry I never received any messages from you... But yes it's been crazy busy the last few months really.
    From my experience, the actuator speeds can be misleading. I've gotten response time down to around 10ms now, which is really responsive. Some actuators might advertise high speed, but try and find out what the response time is as well, in the video above that certainly isn't 960mm/s...
    For 6 axis we can do a full motion ballscrew kit (Cabinet with all electronics, motion controller with an ethernet interface to simtools , simtools license, 900W motors and actuators for $7000), the ballscrew coupling I use ensure a high mechanical bandwidth without any flex, allowing for some more aggressive PID tuning.
  11. isamu
    isamu Member
    279Coins
    Did you ever go through with this? And are there any pics of this setup?
  12. isamu
    isamu Member
    279Coins
    Hi. Can you post a link to a picture gallery of this system? And if possible a vid?
  13. Gadget999
    12,331Coins
    I did not buy. I think i can make my own for a lot less
