1. We have a few rules which you need to read and accept before posting anything here! Following these rules will keep the forum clean and your stay pleasant. Do not follow these rules can lead to permanent exclusion from this website: Read the forum rules.
  6. Do not share user accounts! Any account that is shared by another person will be blocked and closed. This means: we will close not only the account that is shared, but also the main account of the user who uses another person's account. We have the ability to detect account sharing, so please do not try to cheat the system. This action will take place on 04/18/2023. Read all forum rules.
Mdbox 4DOF need help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by JasonHim, Aug 3, 2019.
  1. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    updated latest drivers on controller and for usb ports,still not working
    also the numbers in the lcd display on the md box keeps continuosly running
    crap i should select amc in interface
  2. LukeBrown
    LukeBrown New Member
    461Coins
    I had this same issue. It would work when I pressed buttons on the nano controller but then not on Simtools Axis test. The way I fixed it was to have everything switched on and then press the reset button on the nano controller. Doing that seemed to sync my computer to the controller and then it could see it. Also make sure you have the same IP address in both game manager AND game engine, I had to change mine to make them match.
  3. James Schokman
    James Schokman New Member
    - 36Coins
    3DOF, Motion platform
    Hi. I have the same controller box and AMC box. Not sure what the model numbers are. I'm wondering how to recalibate a motor. I've replaced the bearings on one motor but the controller (the big silver box) spinds up the motor then gives a spd error in the display. Any idea how to recalibrate the motor?
