Michaels SFGT Wipermotor Simulator
Discussion in 'DIY Motion Simulator Projects' started by Michael N., Jan 6, 2008.
  1. tronicgr
    tronicgr
    Re: Michaels Racing-Rack-Professional Nachbau
    Hey, where did you dig this up? :lol:
    Be aware that the DSMhb1.3b uses IDC connector!!! That means that you need to make a cable that is 10pin Molex in one side (connected to the AMC1.5) and 10-pin IDC one the other (connected to the DSMhb1.3b)
    Here is an example of how this cable was made in the past to be used with the (not so good) RNVN2 motor controller!
    post7208.html#p7208
    Anyway, here is the correct file you should use that has molex connectors on both AMC1.5 and DSMhb1.2b !!!
    Regards, Thanos
  2. egoexpress
    422Coins
    I thought it would be worth to reduce the overall number of molex connectors even by one.
    I really dont like the molex, as you have to solder each wire on them manually.
    And if the h-bridge will be used some day with your ultimate controller, it will be compatible regarding the connector.
    Regards
    Christian
  3. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Hi Thanos and Christian :) ,
    thank you for your help :thbup: , but which one should i take now 8) .
    @ Christian
    Wenn ich mich für eine PDF-Datei entschieden habe :D , dann schicke ich die dem Heinz und er fertigt mir diese an.
    Später muß ich sie ja dann noch mit den entprechend Bauteilen bestücken. Ich habe mal in der Teileliste geschaut unter anderem einen Mikrocontroller entdeckt. Läßt sich dieser denn eingermaßen gut verlöten oder sind das super winzige Lötpunkte?.
  4. tronicgr
    tronicgr
    Hi Michael,
    Take Christian's advice and use this: post9431.html#p9431
    He is right that I decided to use IDC connectors only on my new UAMC2.0 controller, and that's why also converted the DSMHb connector to IDC (in DSMhb v1.3b).
    It won't be hard to make the molex to IDC cable, you can see how here: post7208.html#p7208
    Oh, and the ATmega microcontroller is not so micro in size too! :lol: Its DIP40 package and its easy to solder it as its through-hole component!!!
    Regards, Thanos
  5. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    OK, thanks.
    I send the PDF.File to Heinz pcb etching-service :clap: .
    Now let`s have a look to the Partlist which parts i must order. :)
  6. egoexpress
    422Coins
    Jo, alle Bauteile sind in Stecktechnik. Du solltest aber für alle sensibleren Bauteile besser Sockel verwenden. Sind die Sockel einmal aufgelötet, kann man Bauteile einfach in sie hineinstecken. So kann es nicht passieren, dass man den Mikrokontroller mit dem Löteisen grillt. Passiert normalerweise auch nicht, aber für Lötanfänger sind Sockel und Sockelleisten immer besser.
    Schwierig zu Löten wären SMD (surface mounted devices) Bauteil, da die Lötpunkte winzig sind. Aber von diesen sind auf dem AMC1.5 keine drauf. Thanos hat es extra lötfreundlich gestaltet. Also nur Mut.
    Gruss
    Christian
  7. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    i found the Partslist for the AVRmc 1.5c Here on the 1st Side (right?). But were can i find the Partlist of DSMhb1 3b ?. I only found the Partlist of DSMhb1 2b, or is it the same?. Which Partslist are up to Date?.
  8. egoexpress
    422Coins
    3b hat die gleiche Bauteilliste wie 2b, bis auf einen einzigen Stecker. Weiß gerade net wie der genau heißt.
    Gruss
    Christian
  9. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    :clap: Heute sind die Platinen angekommen 8) .
    Jetzt muß ich mich noch um die Teile kümmern. Ich werde bei Reichelt mal schauen.
  10. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    ich stelle gerade die Teileliste für den Dual simple H-bridge 1.3b Platine zusammen. Bei Reichelt.de habe ich schon einige Teile entdeckt, ein paar Sachen finde ich aber nicht. Vielleicht kann mir einer helfen.
    Folgende Teile habe ich nicht bei Reichelt gefunden, wäre nicht schlecht wenn einer eine alternative Reichelt Bestell Nr. dafür hätte.
    4x - Terminal connectors (two legs) atleast 15amp rated on 125volt
    8x - Terminal connectors (three legs) atleast 15amp rates on 125volt
    1x - 10pin Male Molex connector
    2x - 10pin Female Molex Connector + 8 metal pins
  11. christian
    christian Member
    Germany/München
    967Coins
    2DOF, SCN5, SimforceGT
  12. christian
    christian Member
    Germany/München
    967Coins
  13. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Danke Christian, war genau das richtige :) .
    Für den 10 poligen Verbinder habe ich 2 x 5 polige (Link) jeweils in braun und weiß genommen. Da auf der aktuellen Platine die 10 pole nicht in einer Reihe sind, sondern nebeneinander, müßte doch passen oder?.
  14. RaceRay
    23,884Coins
    Hi Michael,
    Ich hoffe die Lochborhungen passen, da da diese ursprünglich für Molex Stecker gesetzt wurden sind. Sag dochmal ob die Stecker ganz ohne Nachbohren gepasst haben, wenn Du mit montieren fertig bist.
    Kannst Du vielleicht auch die H-Bridge Reichelt Stückliste (gespeicherter Warenkorb) als Link mal veröffentlichen? Den könnte Thanos in seiner Anleitung ergänzen.
    Grüße
    René
  15. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Das wollte ich aufjedenfall machen. Ich wollte eine Stückliste für die H-Bridge und eine für den Controller machen. Ist es möglich bei Reichelt 2 verschiedene Warenkörbe abzuspeichern?. Bis jetzt ist es mir nur gelungen, 2 Warenkörbe aber nur mit gleicher Benennung abzuspeichern.
  16. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    So, meine Teileliste bei Reichelt.de für die H-Bridge DSMhb1.3b habe ich so gut wie fertig. Vielleicht kann nochmal einer kurz kontrollieren, bevor ich bestelle :D
  17. RaceRay
    23,884Coins
    Hallo Michael,
    hab mal das Thema zu den DIY Simulatoren verschoben. Mittlerweile ist es ja kein Rack mehr sondern wird ein ausgewachsener SIM :clap:
    Ich werf gerade einen Blick auf Deine Teileliste, spontan ist mir jetzt der fehlende Kühlkörper aufgefallen...
    Es ist möglich mehrere Warenkörbe bei Reichelt zu speichen, wenn ich zuhause bin, schau ich mal wie das funktioniert, kann mich dran errinern, dass die Funktion nicht ganz intuitiv gewesen ist.
    Hab mal ne blöde Frage, warum ist die 1.3b Platine nicht bei Thanos im ersten H-Bridge Post aufgeführt? Finde nur die 1.2b..gebe auch zu, dass ich den H-Bridge Thread nicht ganz gelesen habe...Was sind die Unterschiede zwischen den Versionen?
    Viele Grüße
    René
  18. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Steht auf Seite 3 ;) . Der einzige Unterschied ist, der 10 polige Molex Stecker auf der Platine wurden gegen einen 10 poligen IDC Stecker getauscht, dementsprechend ist das Platinenlayout leicht verändert.
    Kühlkörper muß ich noch schauen.
    EDIT: Kühlköper wollte ich mir aus einem Alu Winkel selber basteln, so wie es Thanos in dem THREAD [klick] (letzter Post) auf Seite 4 gemacht hat :) .
  19. RaceRay
    23,884Coins
    So, hab auch beim genaueren Hinsehen keine Teile vermisst... Bestellen :D :hi:
    Wenn ich bei reichelt angebe, Warenkorb speichern und einen anderen Namen angebe, kann ich beliebig viele Warenkörbe speichern und mit Warenkorb laden wieder hervorholen. Hab ich eben getested ...it works.
  20. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    ich wollte am Wochenende mit dem löten der Platinen anfangen :cnotb: . In dem Lötguide (Solder Guide) von Thanos steht geschrieben, das man die dicken Leiterbahnen auf der H-Bridge Platine mit ziemlich viel Lot aufdicken soll. Muß ich das mit meinen Platinen auch noch machen oder ist das mittlerweile nicht mehr nötig bzw. noch aktuell ?.
