Icy7CE
Microsoft Flight Simulator 2020 Plugin 1.1.3.0
SimTools Plugin for Microsoft Flight Simulator 2020
  1. Camerus
    Camerus Sim builder
    California
    46Coins
    Motion platform, 4DOF
    Great job sir and thank you again!
  2. Zeraxx
    Zeraxx Member
    188Coins
    Works perfectly, no motion stops anymore!
  3. Icy7CE
    Icy7CE Active Member
    USA
    2,886Coins
    It occurred to me that it would be easier if I just included SimConnect.dll in the plugin download, rather than copying it from the game installation directory. The concern I had, though, is that different versions of the game might use different versions of this file. Can anyone with the MS Store version help me test this by trying out my version of SimConnect.dll?
    Just follow the instructions to patch the game, and then replace the file in AppData\Local\SimTools\MFS2020.
  4. Scott clow
    Scott clow New Member
    - 17Coins
    4DOF
    I'm having permissions issues when copying SimConnect.dll out of the MS Store install directory. So I used your .dll... seeing this error on start of MFS: Open exception: Arithmetic operation resulted in an overflow. However I now have motion
  5. Icy7CE
    USA
    2,886Coins
    Thanks for the info. It seems to always output that error message when the game is loading, but it goes away by the time the main screen comes up.
  6. Snajrog
    Snajrog New Member
    35Coins
    Arduino, Motion platform
    It did not. But your revision worked as I had a 1.5 hour flight today with a bunch of turbulence and it worked the whole way!!! Awesome effort, thanks!
  7. Camerus
    Camerus Sim builder
    California
    46Coins
    Has anyone experienced these with the latest version of the plugin:
    - staticky sound with micro cuts
    - every time I come back to the menu the rig shakes violently for a short period of time
    Am I the only one experiencing this?
  8. Aron de Haas
    Aron de Haas New Member Gold Contributor
    - 117Coins
    Thanks for the update.
    Some issues i have, still getting the overflow error but it seems it keeps working now.
    Issues
    Biggest issue is YAW. Its set to -180 on loading, and when plane is loaded it sets it to a different value but not zero
  9. msverickmace
    msverickmace New Member
    - 7Coins
    2DOF, SCN5
    its not working for me. game appears to be patched fine, but the UDP says:
    Open exception: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
  10. alfsin
    alfsin New Member Gold Contributor
    España
    - 1,019Coins
    for me now it works very well, the only problem is the yaw that does not respond in the movement platform
  11. Icy7CE
    USA
    2,886Coins
    Try turning down the game graphics and/or the packet rate in the config file, and let me know if this helps with the micro cuts. Also, does the rig shake violently whenever you pause the game mid-flight, or just when returning to the menu after exiting a flight?
  12. Icy7CE
    USA
    2,886Coins
    -180 is the value the game outputs when loading, so I'm not sure there's anything I can do about this. And once the plane is loaded yaw is set to its compass direction, so it won't be 0 unless the plane is pointing directly south.
  13. Icy7CE
    USA
    2,886Coins
  14. Icy7CE
    USA
    2,886Coins
    Since yaw goes from -180 to 180, a wide range of values, it typically doesn't change as drastically as pitch and roll. There might not really be a problem with your setup.
  15. Snajrog
    Snajrog New Member
    35Coins
    Reference the SimTools manual as there is a section for this. You’ll also need to install the Plugin Updater if not done so already.
    FWIW if you haven’t done so already read through the manual in it’s entirety. Not all will make sense but as you start to become familiar with ST things will click easier.
    I’m a visual guy too but you really need the manual as a reference.
  16. Aron de Haas
    - 117Coins
    Nah yaw just isnt working as it should. Might be plane related not sure where you binded it to.
    Rest works ok, will you be able to build in protection for pitch and roll? So max 360 degrees or something.
    Unfortunly after 10 hours of testing MFS2020 is a pain in the ass. Crashes mid flight all over the place.
  17. Camerus
    Camerus Sim builder
    California
    46Coins
    Thank you! I will give it a try after work
  18. Icy7CE
    USA
    2,886Coins
    Can you describe your issues with yaw? It's supposed to be the compass direction that the plane is pointing, and on my machine it always is. I tested with several different planes.
    For me, the value of roll seems to always be bounded by -180 and 180, and pitch by -90 and 90. Were you getting values outside of these bounds?
    Also, do you mean that the game is crashing or the plugin?
  19. msverickmace
    - 7Coins
    2DOF, SCN5
  20. craigN
    craigN New Member
    - 131Coins
    Massive thank you Icy7CE for all you have done here, this was worked perfect for me (MS Store version)
