value1
Microsoft Flight Simulator X / Lockheed Martin Prepar3D Plugin 2.0.2.0
SimTools plugin for Microsoft Flight Simulator X and Lockheed Martin Prepar3D
  1. Historiker
    Michigan USA
    9,212Coins
    • Disagree Disagree x 1
    154,711Coins
    +11,210 / 57 / -2
    Google Translate -Hello after attempt Have All the plug-in and does the possible manipulations to fonctioner my 2DOF With FSX I have an error message "Stop simtools GameManager a trabalho" Then edge program! Have you make an idea to help me sí can thank you
    Try this to resolve .NET issues: http://www.xsimulator.net/community/faq/fsx-prepar3d-net-error.156/
  3. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    I am new on Simtools.
    I have a 2DOF platform. May i know what effects i can get on FSX?
    Will it have any Force feelback on something like Taxing on ground,Take off ground effect or touch down effect?
    Or just Pitch and Roll?
  4. Historiker
    Michigan USA
    9,212Coins
  5. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    Is that mean all surge,sway, heave acceleration can reproduct by 2DOF?
    154,711Coins
    +11,210 / 57 / -2
    A 2DOF can do a pretty good job of simulating surge, sway and heave using the pitch axis and SimTools management and tuning of forces, but it does not exactly reproduce those.
  7. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    Tks noorbeast and Historker. I will try to setup on it.
  8. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    @value1 May i know what will Game Manager add/change to my FSX. I afraid it will destory my FSX setting(Totally got 200GB w/plugin installed). I don't want re-install with patch fail....
  9. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Does this suffer from the same roll error as in the DCS world plugin ????
    ( on rocker seat the motion "flips" at 180 degrees )
    154,711Coins
    +11,210 / 57 / -2
    The plugin has additional options in Extra1 and Extra2 where pitch and roll are implemented like with the Elite Dangerous plugin, to be a continuous effect rather than the flip you get at 180 degrees with tradition pitch and roll.
  11. BlazinH
    16,703Coins
    Technically, this is not an error. Roll and pitch data indicates what the attitude indicator indicates!
  12. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Thanks , seems the FSX plug in is a good one
    On the DCS the roll is unusable on rocker seat type setups,
    I wonder if this will ever be sorted. (pitch works perfect )
  13. BlazinH
    16,703Coins
    Maybe @OldGuy can assist with that one.
    Deriving Euler Angles From Game Data
  14. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
  15. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Microsoft Flight Simulator 2004 (FS9) Plugin 3.0.0.1 ,
    DashApp Data:
    Additional values (1120!) for instruments are feasible, yet not implemented.
    Microsoft Flight Simulator X Plugin 3.0.1.1
    DashApp Data:
    Additional values (800+) for instruments are feasible, yet not implemented.
    :cheersSomeone would have a tutorial on this?
    Is this the same approach in FSX and in FS2004 ?o_O
  16. yjgogqqq
    yjgogqqq New Member
    河南省禹州市
    241Coins
    Could I ask you which way you had written the Game Plugin for SimTools?UDP packets? Memory Mapped Files? Memory Hooks?or other?
  17. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Nobody tried! ...
    No small example! ...
    No tutorial! even in draft ...
    All information FS2004 (FS9) and Fsx about DashApp Data are precious
    Personne n'a essayé ! ...
    Pas de petits exemple !...
    Pas de tuto ! même en brouillon ...
    Toutes les informations FS2004 (FS9) et Fsx à propos de DashApp Data sont précieuses
  18. value1
    14,294Coins
    For FSX see here:
    https://msdn.microsoft.com/en-us/library/cc526983.aspx
    For FS9 see here:
    http://www.schiratti.com/dowson.html
  19. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Thank you for the 1st track Fsx and Fs2004
    Someone has already used these 2 software with Gamedash of SimTools?
    - SimConnect
    - FSUIPC4
    I will try to study these tracks to Google Translate.
    Glupps ... it is not necessarily won!
    Any additional help and expertise will be appreciated ...!
    Merci pour la 1ére piste pour Fsx et pour Fs2004
    Quelqu'un a déjà utilisé ces 2 logiciels avec Gamedash de SimTools?
    - SimConnect
    - FSUIPC4
    Je vais tentez d'étudier ces pistes à la de Google Translate.
    Glupps... c'est pas forcement gagné !
    Toute autre aide complémentaire et compétence sera apprécié ... !
  20. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Do you know if you need to save for use with FSUIPC GameDash?
    Savez- vous si on a besoin d'enregister FSUIPC pour l'utiliser avec GameDash ?
