Motion Sim w/ Surge & Traction Loss
Discussion in 'DIY Motion Simulator Projects' started by Boomslangnz, Oct 26, 2014.
  1. noorbeast
    154,738Coins
    +11,195 / 57 / -2
    Are there any errors being reported in the JRK setting interface tab?
  2. Boomslangnz
    4,172Coins
    Hey guys,
    Been awhile since I posted on this but I need some advice and help on my poor design of Traction Loss, basically it doesn't work well at all and the motor just fails at attempting to move the sim mostly just throwing out drive errors more then moving the darn thing. I initially thought it may be due to the weight of my unit and upgraded it to a 60:1 believing I needed more torque but today I installed the new motor and the same problem remains so its obviously the design of my traction loss which isn't good.
    It swivels on a 12" lazy susan bearing and currently has 3 x roller blade wheels with bearings on the rear (it moves pretty easy by hand left and right), ill show a pic of it awhile ago which is still essentially the same as how it is now
    I had to put the motor in this position as I just didn't have room anywhere else for it to avoid the surge ontop messing with it
    Any tips and ideas to help me out here guys?
  3. SeatTime
    First just drill/move to a hole closer to the motor on the lever to see if it is torque issue and work from there. FI, I used a bicycle rear cog on the motor and chain for surge and traction loss on my old sim. Actually all your levers look quite long. What wattage are those motors?
    154,738Coins
    +11,195 / 57 / -2
    I agree with @SeatTime , shorter levers are the place to start.
    Try 60mm CTC. You could come back further than that if you needed to, I run 50mm CTC on my 60:1s.
  5. bsft
  6. Boomslangnz
    4,172Coins
    yeah you guys were right, set one at 65mm and it worked fine. So now trying it at 110mm (as a hole was already drilled there) and its working pretty good but I may end up setting it around 80-100mm in the end as it seems plenty of movement
    I was testing it at 130mm which obviously was too much torque required
    Thanks for the help!
  7. Nick Moxley
    17,057Coins
    I'm on 100mm and no issues.
  8. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,951Coins
    Well done :thumbs and just keep on touch ...
  9. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    Like your rig!!...Traction loss will be my next upgrage:)
  10. Boomslangnz
    4,172Coins
    new question,
    Ive found that if I have max duty and Acceleration in jrk config set to 500 for both that I keep having the motor like stall up or something and do this
    It stops after a bit of driving however as soon as I drop max duty and Acceleration down to 300 for both the motor works perfect and moves me with ease etc and I never have this problem
    Just interested as to the cause of this more then anything as it works perfectly fine at 300 so I'm happy with the result
    Anyone had this happen before and knows the cause?
    154,738Coins
    +11,195 / 57 / -2
    Can you post screenshots of your JRK settings.
  12. bsft
    Ok. Motor could need individual tuning. Work with PID and motor settings to see if it stops it. All it takes is a few windings more or less in the motor that can make it do strange things. Also , send video to motor supplier and they can listen and maybe advise.
  13. SeatTime
    Yea, had that on my old sim if I drove the JRKs too hard (200W motors). Just use the setting that will not overload the JRK.
  14. Boomslangnz
    4,172Coins
    Just a updated vid showing my father in law having a bit of fun on iracing for his first racing experience
    • Like Like x 5
  15. michto35
    michto35 Member
    france
    92Coins
    thank you for sharing the video, I love your installation with the projector
  16. bsft
    wow thats real immersive
  17. Pit
    30,516Coins
    Great rig, congratulations! To be honest only one remark about the motion profile, there is still more potential IMO. F. eg the lack of "Heave" and more direct "sway" respectively more aggressive but less shaking.
    Edit : sway does not work obviously...which forces did you choose on SimTools?
  18. Nick Moxley
    17,057Coins
    Agree with Pit on the Fine tuning required, But also whats the Clunking noise that i can hear ?
  19. Boomslangnz
    4,172Coins
    Yeah I was doing some fine tuning with @eaorobbie last night actually getting the most out of PID etc as I knew it wasn't perfect at all, trying a few things out. not sure what the clanking noise you are referring too really, but I did damage one of my gearboxes during our PID testing last night during my excessive crashes so that needs to be sorted now
    They are 50:1 ratio motors so I'm not gonna get the speed of 25:1 however
  20. Nick Moxley
    17,057Coins
    Oh my, what damaged on the gear box ? They sure are strong bugger's aren't they, Lol. Wiggle the rig around, see if you can trace it down, Check the U-joint for a wiggle...Or maybe it was just the video picking up a minimal sound and amplifying it.
