Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,741Coins
  2. yobuddy
    51,741Coins
    GameVibe is being tested by Santa right now!
    It should be along shortly. (I need to finish the how too to be able to post it)
  3. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Are the 2.1 plugins compatible?
  4. yobuddy
    51,741Coins
    Yes, The plugins technically are v2 plugins and they will work for all future v2 releases.
    (v2 plugins always had the ability to support GameVibe, but they will need updates to actually send data to GameVibe.)
    (At the time I had no idea exactly how i was going to pass the data, well that is all solved now)
    Take care,
  5. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    @yobuddy wow thank you for further evolving! However in case i use serial interface - can i keep Roaming data in app/local folder to prevent setting all values again? The update goes just like uninstall old-install new routine or it's more like click-update thing?
  6. yobuddy
    51,741Coins
    @hazardic
    Just Install over the top to update.
    No need to re-setup all over again.
    (but if you have scn's then remove the interface for them before updating., and re-set them up after the update.)
    Take care,
  7. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    instaled. working like a charm. Waiting for simvibe interface ! tks
  8. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    @yobuddy thank you, appreciate your work!
  9. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    wow... working through Christmas time for our benefit..... Thanks yoBuddy!!!
  10. yobuddy
    51,741Coins
    I just want to say thanks to everyone for being so patient with this v2.2 Release and GameVibe.
    Trust me when i tell you I know how long it took. :D
    Because it has so much new code for GameVibe, and because I needed to try a million different ways to use GameVibe to see what works best, it just took forever testing and testing and testing....
    I could not release anything less.
    I just can't do it. lol
    And now that so much of the code has been polished and GameVibe is complete, I expect future updates to be much easier.
    I'm excited with some of the other stuff I have planed, and with this completed, I get more time to try out new things!
    So to all of you that help to make this hobby so much fun, here's to you! :cheers
    • Like Like x 15
    • Winner Winner x 4
  11. L.Dörenberg
    L.Dörenberg beginner Gold Contributor
    car bodyrepair
    Netherlands
    - 65Coins
    Thanks yobuddy for the amazing hard work you've done! Very happy with it, cheers. Leroy
  12. Raymann
    Raymann New Member
    278Coins
    Excellent job, buddy :thumbs:thumbs:thumbs:p
  13. Jeongkyu Wi
    Jeongkyu Wi New Member Gold Contributor
    Seoul, South Korea
    - 344Coins
    SCN6, SimforceGT, Motion platform, 6DOF
    I have confusing that how can I assign 2 SCN axis on single adapter?
    There's only 1 COM port option and 2 assigned axis, so I couldn't assign them on it.
  14. Jeongkyu Wi
    Seoul, South Korea
    - 344Coins
    As I understood, I need to connect both SCN as setting different Axis No. to single RS485.
    Is it right?
  15. noorbeast
    154,675Coins
    +11,209 / 57 / -2
  16. Jeongkyu Wi
    Seoul, South Korea
    - 344Coins
  17. noorbeast
    154,675Coins
    +11,209 / 57 / -2
    Sorry yes 2.2 does support 2 scn's per interface: https://www.xsimulator.net/community/threads/simtools-v2-2-is-out.11334/
  18. yobuddy
    51,741Coins
    @Jeongkyu Wi
    Hi Buddy,
    You actually can connect 2 SCNs to a single RS485 adapter now. :thumbs
    You will need to configure the axis ID of one of the SCN's actuators to use 2 on the same adapter.
    One is already set to ID = '0' (they come this way, so you really only need to change the other one) and the other SCN needs to be set to ID = 1.
    The wire them up to the same adapter.
    And you should get action buddy!;)
    Take care,
  19. Jeongkyu Wi
    Seoul, South Korea
    - 344Coins
    Awesome!!
    Thanks a lot and I will try it as your advice!
  20. yobuddy
    51,741Coins
    @moaale,
    Send a message to the help desk.
    https://simtools.us/contact-us/
    This way it will get logged into the system so we can help you buddy. :thumbs
    btw, simply formatting a machine does not count against your activations (unless you change hardware or something).
    Hope you got some good new equipment buddy!
