Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,741Coins
    @pmvcda,
    Windows Defender has this problem with almost every update.
    It will disappear with a bit of time.
    But if you want to install AVG free, the problem will be gone forever.
    Take care,
  2. misoswan
    misoswan Active Member
    1,038Coins
    3DOF, Arduino, JRK
    Hi latest firmeare not work for my . Tested on 2.2.5
  3. yobuddy
    51,741Coins
    @misoswan
    You need both SimTools v2.3 and thanos's latest firmware release on the 1280 AMC for it to work.
    Take care,
  4. misoswan
    1,038Coins
    3DOF, Arduino, JRK
    Hi
    when used firmware2.0 (thanos) and yout 2.2.5 all work correct!!!! .
    when stay firmware2.0 (thanos) and your 2.3 firmware all engine not work!!.
    when swop firmware2.0 to v3.0_rev2a.hex(thanos) and used your 2..2.5 work only 2 engine.
    when in firmware v3.0_rev2a.hex and your 2.3 again 2 engine not work.
    Michal
    have 3 dof platform
  5. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Thanks @yobuddy for the SimTools/SimVibe update!!! :thumbs
  6. baxbax
    baxbax New Member
    135Coins
    Installed Simtool and Simvibe update.
    It's all OK!
    Thanks @yobuddy
  7. George Dobransky
    Hungary
    - 37Coins
    Hi There,
    I just installed 2.3, but I have strange unusable movements in games. If I test it at game engine's output testing, at minus values it gets strange movements.
    I mean if I pull the roll slider to right, (positive values) it's OK, but at 0, or negative values (left) I got strange movements.
    2.0 still works great.
    Any Ideas????
    I'm using AVG only.
    George, Hungary
    154,675Coins
    +11,209 / 57 / -2
    Is your computer set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  9. George Dobransky
    Hungary
    - 37Coins
    noorbeast,
    Thanx buddy, it has solved the problem!
    Cheers,
    George
  10. Psionic001
    Psionic001 Active Member Gold Contributor
    Sydney
    997Coins
    Motion platform, 6DOF
    hey guys,
    simtools game engine and game manager completely dissappeared from my computer overnight. absolutely no idea how they dissappeared, so without another thought I downloaded 2.3 and installed it.
    Now months and months of tuning presets have dissappeared from my AxisAssignmentsPresets folders... This is heartbreaking!!!
    Can anyone recommend a way to get them back? I don't have a recent backup.
    154,675Coins
    +11,209 / 57 / -2
    I think you first need to work out what happened, a program like SimTools does not just disappear overnight without something happening. Was it an accidental deletion or uninstall, a virus or a hack, or perhaps a windows update gone wrong?
    Getting anything back without a backup is unlikely, for future reference here is how to make a SimTools backup: https://www.xsimulator.net/communit...thout-loosing-your-profiles-and-settings.160/
    Do you have system restore enabled on the computer?
  12. Psionic001
    Sydney
    997Coins
    Thanks,
    No virus, and nothing else on the computer is affected. Only thing I'd done recently was install the new version of HexPod (V2.1).
    And then noticed my usual Game Manager/Engine desktop shortcuts had disappeared. I don't think this has anything to do with HexPod, it's just that is the point when I noticed.
    No windows updates had been done either. I realise these apps just don't disappear, and I have not been fiddling with the Simtools folder for months. That's why I'm baffled, (and upset)
    Is it possible to change where the AxisAssignmentsPresets folder is located so I can from this point forward keep it in my dropBox for example and not have it wiped when a new version is installed?
    The only thing I have now is some photos I took of the screens a few months ago during tuning, but they are probably not the refined settings I was using.
    So on this note, can I ask anyone using HexPod plugin for SimTools if they have a library of presets for common games that they may want to share?
    If not, no worries. I'll eventually get mine redone, then upload them here so others can grab them.
    I am not sure if I have restore enabled. Does that restore everything? Or can I restore individual folders?
  13. yobuddy
    51,741Coins
    The AxisAssignments Presets folder never gets messed with when updating SimTools.
    Maybe a false positive from a antivirus or something?
  14. Psionic001
    Sydney
    997Coins
    Good idea!! I’ll check that when I get home.
    I think AVG has a quarantine area.
  15. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    How many times can a valid License key be used?
  16. yobuddy
    51,741Coins
    One license is meant for one setup of SimTools.
    But re-registering on the same PC does not count again activations.
    If you have any problems, you can always buzz us here:
    https://simtools.us/contact-us/
    Take care,
  17. Phaze11111
    Phaze11111 Member
    Central Indiana - USA
    - 41Coins
    3DOF, SCN5, Arduino
    Is there a way to uninstall and reinstall if/when I build a new PC?
  18. yobuddy
    51,741Coins
    Yes, Uninstall from the Old PC first, Then install on the new PC.
    If you have any problems, please send us a note here.
    Take care,
  19. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,962Coins
    Searched, but didn't find anything.
    So, I was trying to get a binary output from a memory mapped file.
    I don't know if it's my code, but it seems that any byte above 127 is converted to 63.
    Usually that's an encoding problem.
    From what I tested, the string in the output is not formatted in the correct encoding.
    Maybe it's on my side, but I thought it should come out right.
    I'm unable to read the bytes and convert them to a correct value (was trying with 16 bit, since I'm already reading 2 bytes).
    Maybe I'm getting the info the wrong way. Or can it be a bug?
    Also, what is the order of the bytes? 1st high and second low or reversed?
    Fist high would be better to make a readInt16. But from the manual, I think it's reversed.
  20. yobuddy
    51,741Coins
    @pmvcda,
    Please try this buddy,
    Take care,
