Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Niko77
    Niko77 Member
    343Coins
    3DOF, DC motor
    why we don't have Lateral force, Vertical force, Longitudinal force input like in X-sim? I have not the same feeling.
  2. value1
    14,294Coins
    Lateral force = sway
    Longitudinal force = surge
    Vertical force = heave
  3. Niko77
    Niko77 Member
    343Coins
    3DOF, DC motor
    ok thanks.
    Is the plugin of Asseto corsa work the "new" asseto (pre release)?
  4. value1
    14,294Coins
    Niko77: If you can help me out (I currently don't have AC Early Access) we can make it work in no time.
    Please let me know.
    Thomas
  5. Niko77
    Niko77 Member
    343Coins
    3DOF, DC motor
    I make a try, and it's not working. When i start Asseto Corsa, Simtools don't start.
  6. value1
    14,294Coins
    Yes, because I need your help first ;)
    I will send you a PM later, how we can make it work together.
  7. John05
    John05 New Member
    - 19Coins
  8. John05
    John05 New Member
    - 19Coins
    I tried to download Sim tools but it will not download. Does anyone have a copy of it they could email to me?
  9. Historiker
    Michigan USA
    9,212Coins
    Hmm...download link is working for me on three different computers.
    Did you go to this page?
    http://www.xsimulator.net/community/marketplace/simtools-v1-0.63/
    In the upper right corner is a big orange button that says "Download Now 3.5mb .zip"
    Let us know if that button is not working and what error message you get if it is not.
  10. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Yobuddy,
    New SimTools is great, so much easier and straight forward, really like it so far (1 day of use)! :)
    Ref. to my post here: http://www.xsimulator.net/community...ion-to-x-sim-new-updated-way.4946/#post-48224
    I would like to suggest that we should be able to see and edit the SCN actuator ID inside the Game Engine / Interface Settings.
    I had problems and I believe everybody coming from a Frex system will have too as each actuator will come with different IDs, 0 and 1 probably.
    Thanks!
    MY
  11. yobuddy
    51,747Coins
    Hi @MasterYoda,
    This is a great idea, but I don't have a SCN to test with, as my buddy with them moved to a different state.
    I believe the SCN PC tool has this capability thou, could you take a look?
    http://www.automation4less.com/servact1.htm
    Software is at the bottom of the page.
    Thanks buddy!
  12. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Long time ago we chipped in to buy a SCN5 for development... Not sure if it is still around and working, tho.
    I believe the SCN PC tool might do the trick, but it didn't install here, not sure if W8 or some other issue.
    I still think using an old xSim might be easier and safier, to not mess up with other settings... :)
    Thanks.
  13. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    But the development for the K8055 has been abandoned or is there hope for us?:think
    Anyway congratulations for the great work you are doing
  14. eaorobbie
    20,506Coins
    No one with a K8055 sim and vb net experience has picked up the challenge.
    I would upgrade to a Ard UNO and use the firmwares here to bring you sim into the future.
    What H Bridge are you using.?
  15. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    Sabertooth 2X12 :(
  16. eaorobbie
    20,506Coins
    Bugger, No one has released a working code for the sabertooth to be connected to an Ard, only the SimAxe controller has this capabilities.
    I know a few guys have been working on the Kangaroo from Dimension Engineering which is designed to run the Sabertooth, could check they're posts for info.
  17. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    I apologize but I use the automatic translator and sometimes it is difficult comprendere.Volevo ask at this point if I buy an Arduino ver.3 one can go well with sabertoot 2 x 12 and finally use simtools?
    chiedo scusa ma uso il traduttore automatico e a volte è difficile comprendere.
    Volevo chiedere a questo punto se compro un arduino uno ver.3 può andare bene con sabertoot 2 x 12 e utilizzare finalmente simtools?
    • Disagree Disagree x 1
  18. yobuddy
    51,747Coins
    Try using Sway and Surge rather than Pitch and Roll and you should be ok.
    when you use 2 DOF's per axis set both entries to 60%
    What type of Sim do you have?
    if it's a seat mover one of the rolls needs a dir change
  19. bsft
    Why are you using what looks to be an AMC?
    What changes are you refereing to?
    Otherwise looks fine, considering its wipers, perhaps space them out more ot rick chewing them out. If they nuke themselves, use big 12v worm gear motors
  20. eaorobbie
    20,506Coins
    Heavy frame and very weak and slow motors dont help.
    Try lowering the values in the Tuning centre for the game. Ones shipped in plugins are a bit high, done for safety of ones machine.
    ? What is the controller.
    ? What are you using in Axis Assignments and game.
