Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Ipponen
    Ipponen New Member
    - 107Coins
    Great, looking forward to it.....
  2. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    delicious :) will this new version be 32bit or 64bit?
  3. yobuddy
    51,781Coins
  4. yobuddy
    51,781Coins
    It's 32bit buddy.
  5. hannibal
    hannibal Active Member
    4,492Coins
    exciting times again!
  6. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    is there some documentation on version 2.5.3? im running 2.5.1 right now and wondering what is the update?
    154,849Coins
    +11,229 / 57 / -2
  8. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    thanks . yeah ive seen that . its registration update , but there must be more for a new update to move from 2.5.1 to 2.5.3 ?
    154,849Coins
    +11,229 / 57 / -2
    It is a significant and necessary fix for anyone wanting to try out the V3 Beta.
  10. yobuddy
    51,781Coins
    No need for the update then buddy, its just a reg change and it's only needed if v2 is not already activated.
    Take care!
  11. yobuddy
    51,781Coins
  12. yobuddy
    51,781Coins
    SimTools v2.5.4 is required for registering SimTools v3 with a v3 license.
    Take care,
  13. lesley
    lesley New Member
    South Africa
    22Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform
    So I've got a 270deg pot(left motor) and a 180deg pot(right motor). i still feel the motion being inaccurate and that is obvious , or is it? i need some assistance in this regard. the motion platform works wonderful i have to say. but i need more lol. also i need some assistance with tuning. what's the best to tune on ac ? i drove around LAC track without knocking is that good enough? or should i take a track with the steepest inclines-declines-sharpTurns,etc?also what car is best? a super slow? or super fast?
  14. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    Odd pots are just complicating matters, as the resolution will be different, preferably swap them out for some quality hall sensors, something with similar specs to these, shop around and you will find some cheaper than these: https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
    See the FAQ tuning tips, once you have dialed in a good base motion profile you can easily make variations of it for particular cars and tracks: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. yobuddy
    51,781Coins
  16. yobuddy
    51,781Coins
    If SimTools v2 is working for you, there is no need to update at all.
    All that has changed in v2 is the reg app so it knows v3 licenses for registering.
    2.5.5 is the same as 2.5.1 except the reg app.
    Take care!
  17. hannibal
    4,492Coins
    its been a while since i used simtools. i still have a pro license.. can i install 2.5.5 and apply my key, then install v3, or do i have to install 2.5.1 first and increment?
    at the moment my anti virus is trying to clear the 2.5. executables...
  18. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    You can normally just install the latest SimTools directly over the existing install without issue.
  19. hannibal
    4,492Coins
    i have a fresh win11 build so i never had simtools installed after reformatting...
  20. yobuddy
    51,781Coins
    Yep!
