Motion tuning questions
Discussion in 'SimTools DIY Version' started by RayRay, Mar 4, 2016.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    what game, what are you actual settings.
  2. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    iRacing.
    Surge 20%, Max 0.25, Min -0.5
    Sway 60%, Max 1.9, Min -1.9
    Pitch 20%, Max 6.0, Min -6.0
  3. Nick Moxley
    17,057Coins
    No heave or roll ?
  4. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    No.
  5. T-Man
    T-Man New Member
    Telecommunications
    Adelaide
    149Coins
    2DOF, SCN5
    Hey Mate here are my MinMax values amd Axis assignments from iRacing they were set using the tuning centre and the new Mazda MX5 so a pretty subtle car it was done on Bathurst though. I actually went to the presets page and downloaded others presets to get an idea http://www.xsimulator.net/community/forums/game-engine-axes-presets.151/ I also have a Frex rig with the new SimMotion-2 http://frex.xsrv.jp/gpshop/catalog/product_info.php?cPath=1_39&products_id=253 I downloaded most of Rinus Jannsens presets and I found them all pretty dam close to how I like it. but as metions use the tuning the centre to set your own MinMax but even without doing that Rinus adds all of that to his presets. Also definitely 0 out the values of the other forces and work through 1 by 1, this is how I created my Dirt Rally one, which will not be everyones cup of tea but feels pretty darn good on my rig especially doing jumps or the insane Pikes Peak :)
    <_GameName>iRacing</_GameName>
    <_RollMax>6.09148263931274</_RollMax>
    <_RollMin>-6.09148263931274</_RollMin>
    <_PitchMax>13.4103879928589</_PitchMax>
    <_PitchMin>-13.4103879928589</_PitchMin>
    <_HeaveMax>2.20186352729797</_HeaveMax>
    <_HeaveMin>-2.20186352729797</_HeaveMin>
    <_YawMax>179.92057800293</_YawMax>
    <_YawMin>-179.92057800293</_YawMin>
    <_SwayMax>1.91590404510498</_SwayMax>
    <_SwayMin>-1.91590404510498</_SwayMin>
    <_SurgeMax>1.63476204872131</_SurgeMax>
    <_SurgeMin>-1.63476204872131</_SurgeMin>
    <_Extra1Max>2.63037252426147</_Extra1Max>
    <_Extra1Min>-2.63037252426147</_Extra1Min>
    <_Extra2Max>1.20186352729797</_Extra2Max>
    <_Extra2Min>-1.20186352729797</_Extra2Min>
    <_Extra3Max>0</_Extra3Max>
    <_Extra3Min>0</_Extra3Min>
    My Axis Assignments
    Axis 1:(DOF1)Sway 42, (DOF2)Surge 37, (DOF3)Heave 4, (DOF4) Pitch 4, (DOF5) Roll 22
    Axis 2: Same as Axis 1 for Sway, Surge, Heave, Pitch and Roll
  6. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    Thanks T-Man. I will play with those and see how it compares. :thumbs
  7. DaVinster
    DaVinster Active Member
    What does I.T. stand for?
    AB, Canaduh
    1,150Coins
    3DOF, SCN6, Motion platform
    Hey quick question.. when I first run simtools and it calibrates my roll axis is slightly off, leaning more to the left. This makes it feel like you you are taking a hard left turn when driving straight. Any suggestions or a way to 'tweak' the homing values? TIA!
    154,723Coins
    +11,213 / 57 / -2
    If the roll axis is off it will be because of a difference in the physical geometry, or more likely how the controller is set up for the motor/lever. Best to find and fix the problem rather than try and compensate for it.
    • Agree Agree x 3
  9. Leon r
    Leon r New Member
    37Coins
    Guys -
    Real basic question here but when you are sitting in your seat, should axis 1 be the left or right actuator ?
    154,723Coins
    +11,213 / 57 / -2
    It does not matter.
  11. DaVinster
    AB, Canaduh
    1,150Coins
    Thanks! I was hoping there might be an INI file or something like that I could input values to tweak the 'home' position by entering a -1 or something along those lines, similar to the way Tuning Center works.
    Cheers!
    DaV
  12. Tom Theison
    Tom Theison Member
    Machinist
    Indianapolis, Indiana
    69Coins
    2DOF, SCN5
    Hey T-Man, I put your iRacing values into my pCars Tuning center and they work great in there also. Very close to how Frexs motion used to work which I always liked a lot on my Frex rig. Really appreciate the post up there. It gave me a really good base to see just what does what and might fine tune it a little, but its pretty much just how I like it. Thank you.
  13. 9xclubchamp
    9xclubchamp New Member
    Woodbury
    311Coins
    I too have a frex rig and now i'm getting very little motion in my new ProSimu T1000 5 motion rig. can you share your tuning settings
  14. noorbeast
    154,723Coins
    +11,213 / 57 / -2
