Motor driver
Discussion in 'New users start here - FAQ' started by Stahlwolle, Dec 1, 2024.
  1. Stahlwolle
    Stahlwolle Member
    268Coins
    Perfect, that's what I would do too, I just need confirmation again, thanks!
  2. Stahlwolle
    Stahlwolle Member
    268Coins
  3. Stahlwolle
    Stahlwolle Member
    268Coins
    What is the difference between Simtools license and the one you can buy here for 59€, or do I need both?
    154,580Coins
    +11,190 / 57 / -2
    With the shift to the v3 plugin repository system, licensing has moved from Xsimulator to SimTools. In the transition period a valid licence can be used on SimTools v2 and v3, and both can be installed on the same computer.
  5. Stahlwolle
    Stahlwolle Member
    268Coins
    Ah, so i need both?
    154,580Coins
    +11,190 / 57 / -2
    You could use both with a single license if you want, but if you are just starting out it is likely v3 is a bit easier and covers most games, plus the devs are still adding plugins for it.
  7. Stahlwolle
    Stahlwolle Member
    268Coins
    Ok, i bought the premium/best license pack for 59€, but did not get a license key... Where can i find it?
    154,580Coins
    +11,190 / 57 / -2
    I don't think I was clear enough, request a refund as that is for plugin access for v2, you want the license direct from SimTools which if you use v3 also integrates plugin access.
  9. Stahlwolle
    Stahlwolle Member
    268Coins
    It's all very confusing here, I wonder if this is intentional. I wouldn't even know where exactly I need to request a refund. Would I only have access to all V2 plugins with the v3 license?
    154,580Coins
    +11,190 / 57 / -2
    No, to have access to the v2 plugins you need both, though you can earn forum activity coins as an alternate way to access v2 plugins: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    These are the plugins v3 currently has: https://simtools.us/plugin_library/
    It is confusing as there is a history pre v3: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    But as of v3 Beta plugins are now integrated and not backward compatible with v2.
  11. afrobbizz
    afrobbizz Member
    120Coins
    3DOF, 6DOF
    Do you think one 24v 25A is enough to power 2 250w motors with the 100A controller?
  12. afrobbizz
    afrobbizz Member
    120Coins
    3DOF, 6DOF
    And how you put them in parallel? U use jumper wires between the two positive and negative or jumper on the negative and the 2 positive to the diode? Do you also know the power absorbed ac side? Thanks in advance
  13. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,338Coins
    A single 25A power supply will be insufficient; the motors can draw a maximum of 20A at peak, during sudden movements or changes in direction.
