Motor suggestions in USA
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by thechemist, May 16, 2015.
  1. Pit
    30,502Coins
    Who says you need a hundred of amps h-bridge? I am running 1PS winches only by using standard but modified motor drivers...
  2. garyswindell
    garyswindell New Member
    United States
    358Coins
    Are you running geared or direct drive from the winch motor? I needed to run direct and to get the rated torque from the winch motor was on the order of 250 amps.
  3. Pit
    30,502Coins
    ok, 250 amps is a lot. My winches are drawing "only" 120A max and not under normal working conditions, because a motor needs only what he really needs - meaning if there is no weight on the shaft there is no "power" (current) needed to move the shaft. Using my method by connecting any MotoMonster in series the amps are not the limitation factor.
    http://www.xsimulator.net/community...bridge-60a-continuous-and-120a-peak-12v.6537/
  4. garyswindell
    United States
    358Coins
    What model winch motor are you running?
  5. Pit
    30,502Coins
    planetary gear.
  6. Pit
    30,502Coins
    BTW I connect the drivers in parallel not in series...this was only a scenery what is to do generally.
  7. Historiker
    Michigan USA
    9,214Coins
    Gary, not sure where in the US you are but if you have a Harbor Freight close by you can pick up the planetary geared winch for 89.99. You can also order them from their website. There is a coupon available that knocks the price down to 59.99 each but that expires today. If you want, PM me and I will send you the coupon if you think you can get them in time.
