Mover and Aerofly FS2 - Questions
Discussion in 'FlyPt Mover' started by C1500, Nov 25, 2020.
  1. Thanos
    Electronics Engineer
    United States
    2,871Coins
    The only reason for stuttering when spike filter is active, would be naturally wrong Esc/Fine setting, did you adjust them?
    Normally I would suggest restoration of defaults on the AMC-AASD15A controller (exit+Reset), but a little bit context on your actuators may reveal why there is stuttering:
    1. Actuators type? Rotary? Linear?
    2. How much angle or stroke?
    3. If gearbox; Ratio? If ballbearing; Leadscrew pitch?
    4. Servomotor max speed setting? 3000RPM or 5000RPM?
    Also a video that perhaps shows the stuttering will also help if you have any...
    Thanos
