MSFS 2024 Plugin
Discussion in 'Flight Simulator 2020 - FS2020' started by Buj818, Nov 19, 2024.
  1. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    642Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 6DOF
    Hi! I write here because my problem is related to the plugin but different problem. I own a Pro license and recently I configured Vibe for RPM and road but landing gear is present but is not working in any plane. Also I miss flaps too.
    I own a simshaker for aviators that implements quite well the vibrations for (in my case a DIY) butkicker but since I switch from Flypt to simtools is not possible to run it together.
    Is it possible to acces and edit the msfs plugin code to fix it? If not I'll try creating a new plugin with the fixes with AI help.
    Thanks!
    154,645Coins
    +11,206 / 57 / -2
    Can you please clarify if you are using Simtools v2 or v3?
    If you are using multiple programs you have to have a a way to port forward the UDP data, as both can't access the same game data at the same time, this is not an issue of the MSFS plugin code, but rather one of how UDP data is accessed/proceeded between computer programs.
  3. Josh_Possa
    Catalunya
    642Coins
    Thanks @noorbeast, I'm using Simtools V3. I prefer using only Simtools vibe but is not completely implemented (Landing gear is present but not working and flaps is not present). For that reason, if its not possible to edit the plugin to make it working my alternative is run Simshaker for aviators (for the butkicker) at the same time as Simtools (for motion) but as you say, is not possible out of the box.
    154,645Coins
    +11,206 / 57 / -2
    I don't have MSFS 2024, but the SimTools v3 plugin lists landing gear for Vibe, but any issues and requests for improvements (flaps) should be posted to the dedicated v3 thread for dev viability and consideration: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/unread
  5. Josh_Possa
    Catalunya
    642Coins
